The SHP is actually a slightly different casting, but I've put 900hp through them. For the small increase in cost Id go Sportsman as well, with the turbo you do not need the four bolt front cap that the Iron Eagle has. I've had all of them in my hands.
Here's a few differences I know of:
1. The SHP has no boss cast into the front for the oil cross over. (may not be an issue for most)
2. The cylinder walls are a tad shorter then the Sportsman/Iron Eagle (was told this by a DART tech when they first came out, close to a .062" which is not much but it is a difference
3. The lifter valley is thinner
4. The lifter bore bosses have less overall material around them. (may not be an issue for most since the normal guy isn't going to a large diameter lifter of bronze bushings)
5. Main bolts are 1/2 x 13 Grade # 8 on the center and 7/16 on the outer, other blocks are 7/16-14 grade #9+ on both inner and outer (athough many upgrade to studs)
6. The material is different.....
I am off the opinion the Sportman is a Iron Eagle block with a few leff machining operations and 2 bolt front and rear caps.
I do think Dart had to get creative with their marketing so they didn't price themselves out of the market....but 600hp is nothing to a SHP.
While I have built the Man-O-War blocks I would pick a DART over them any day, they are heavier and every single Man-O-War block Ive had leaked in the extra head bolt holes. I now plug them with set-screws prior to doing anything to them. They will hold the power however!
