  • 1994 - 1995 Specific Tech
What cable goes to starter??
  • Thread starter Thread starter str8stang036
  • Start date Start date May 21, 2007
str8stang036
1,382
Miami
May 21, 2007
  • May 21, 2007
I am putting my engine harness back after hiding a lot of things and I cant seem to find the cable for the starter. Can anyone point me in the right direction? Some pics would help..
a_k
170
Saratoga NY
May 22, 2007
  • May 22, 2007
There is a section of the harness which has a power wire, a small black clip which both go on the starter. On this same section there is a bracket that bolts to the underside of the motor mount. I dont have any pics though..
Adam
str8stang036
1,382
Miami
May 23, 2007
  • May 23, 2007
thanks for the reply. I am going to try and find some pics or see another car because I cant tell from what I have.
HISSIN50
34
129
May 23, 2007
  • May 23, 2007
Is your starter cable not connected to the positive battery terminal anymore?
str8stang036
1,382
Miami
May 24, 2007
  • May 24, 2007
Its not that. I just dont know which cable goes to it. There is a cable coming from the starter that says connect to lead.
Is there a positve cable and negative that goes to it?
k00ksta
158
Chicago
May 24, 2007
  • May 24, 2007
Starter Cables
There are 2 wires that go to the starter. They are both 12v. There should be a large red cable that comes directly from the 12v on the battery and straight to the one terminal post of the starter with a nut. then you should have another smaller wire which comes from the High current fuse box starter relay. this wire should have a black terminal that plugs into the starter. It is also 12v but not near the amperage that the FAT red wire that comes directly from the battery is pulling. See here is how that works. The fat red wire 12v 30/40 Amps I believe comes directly from the battery. then the other wire comes from the starter relay which is 12v but low amperage and that basically acts as the switch that closes the circuit between the "GROUND" which is the Frame/body of the car (negative from the battery which is grounded directly to the motor to the right of the water pump on a 94/95) once its closed the starter pulls the power from the higher amperage red wire that is connected directly to the battery. Hope this helps
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 26, 2007
  • May 26, 2007
^ yup, exactly right
str8stang036
1,382
Miami
May 26, 2007
  • May 26, 2007
got it thanks guys!!
k00ksta
158
Chicago
May 27, 2007
  • May 27, 2007
No Problem
Great looks like it helped.
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
Big Posi and Neg wire from Starter to Battery and Alt wires..........
  • from6to8
  • Feb 9, 2026
1994 - 1995 Specific Tech Feb 9, 2026
AeroCoupe
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Electrical Mini-Starter Wiring
  • RekeHavoc
  • Jul 25, 2025
Fox 5.0 Mustang Tech Aug 24, 2025
Mustang5L5
