G guesscrazy New Member May 20, 2007 10 0 0 May 22, 2007 #1 May 22, 2007 #1 Going to use rpm edlebrock heads with the 1.94 -1.6 valves and stock rollers.How big a cam can I go without piston to valve clearance issues?
302 coupe Founding Member Mar 2, 2000 1,952 3 36 Macon, Ga. May 22, 2007 #2 May 22, 2007 #2 as big as you want, so long as the timing events are set up right. BTW, this question can't really be answered with the data you've given.
rbohm Founding Member Apr 12, 2002 6,698 550 204 tucson,az May 22, 2007 #3 May 22, 2007 #3 stay under .500 lift and you should have no problems.
G guesscrazy New Member May 20, 2007 10 0 0 May 22, 2007 #4 May 22, 2007 #4 factory shortblock and pistons, for street and strip.
Max Power Active Member Jul 31, 2003 1,774 1 36 St Paul May 23, 2007 #5 May 23, 2007 #5 The RPM cam is built for those heads.
