ok guys i have 1k to spend on my motor... what all can i have done for that? prices and labor if i have to have it done.? so any tips would be nice
69PaleHorse said:Come'on D. Hearne...can't you see that the guy already has a set of used heads? 88 GT Heads to be exact.![]()
D.Hearne said:I said a NICE set of used heads, not stock used heads. Open your ears.
Appology accepted, I took your previous statement the wrong way.69PaleHorse said:I fear my lame attempt at humor has failed.![]()
My apologies, I stand corrected - you did specify a 'nice' set of heads...though nice can sometimes be subjective.![]()
Back on topic, considering that he does, in fact, have a set of used heads (and appears to have already dropped some time and money into them) maybe some decent port and valve work would help them flow better and you could save some coin for exhaust, headers, and a cam.
Just a thought.
And I also agree with your port and valve work suggestion. But the valve work ( larger valves?) isn't always necessary. I did the set of E7's on my V8 Ranger's 5.0 a couple years ago and left the valves as is. Just opened up the exhaust ports on the sides and roof by at least 1/8 inch all around ( 1/4" in total width, side to side and 1/4 in the roof ) Removed the EGR bumps, and blended the passages into the bowls. The intake sides were left as is, pretty much just port matched and also cleaned up the bowls. These heads work great, with the F4TE high torque roller and 1.7 Cobra roller rockers, the motor pulls strong all the way to valve float at 5500 rpms. It would likely pull farther, with better lifters, but that would stress the stock rod bolts more than I'd like.
