what causes aluminum heads to warp (and need a cleanup mill)
rockin_rick
968
Does this typically ONLY happen when you've overheated the car? Can it be needed when you've blown a head gasket and not overheated it (like I've done)? How many thousanths are typically taken off for a cleanup?
Rick
Blowing a head gasket shouldn't warp the heads, but it may be an indication that they are already warped. If I were you, I'd take them to a machine shop and have them checked for safety's sake. If nothing else, they can mill them, which in your case may be beneficial, because you're N/A, and more compression=more power. Warped heads can cost you a motor bro, it happened to my mechanic's stang. Not worth it IMO.
Aluminum warps when the motor is overheated.. i've seen it first hand with some newer cars taht companies are putting out with aluminum blocks on them.
If your car has been overheated more than once with aluminum heads, chances are they have been warped.
anytime you take off a cylinder head it doesn't hurt to have it surfaced or at least checked.it's cheap insurance to insure that the jobs done correctly and it's not that expensive.personally never believed in the slip and slide method on head gaskets,i've had to redo too many because people before me did this and 6 months later they had the same problem.
If the engine is run continuously with a blown gasket gases rushing around can erode the aluminum head surface.
When overheated, aluminum expands faster than iron so if the heads get too hot they will buckle away from the block to relieve the stress. Depends how much and how often you overheated them, sometimes they warp so much that they cannot be recovered by milling.
I've had MY experiences with the accursed things and will be sticking to solid cast iron here on out.
