what causes cold hard starts
noslow1986
274
oswego Il
what causes cold hard starts. i all ready replaced starter, fix timing,iac, plugs wire cap and rotor, oxygen sensors,battery. could a sensor do this. this did this with my 86 motor and now 91 motor. i tried hooking up my computer tester to it and it beep but the light on the tester was really dim, i already replaced battery. could a act or tps or fuel pump cause this problem. under the intake i have vacuum lines hook up in the back of the intake but not the front facing the radiator. all new vac lines too. would a shop be able to find my problem, i already have bolt on parts will they even mess with it. i know it will cost me some money but at least i known what the problem is. i dont know what to do:shrug:
Fix the no dump codes problem first. There are other methods to use than a handheld scanner. Once you can dump the codes, you can see what the computer is doing.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
attachment.php
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
