What causes this sound....
  • Thread starter Thread starter fuzzyrat123
  • Start date Start date Sep 8, 2009
F
fuzzyrat123
  • Sep 8, 2009
What causes the sound...I have a 90 mustang gt 302...sometimes but mostly when I first start it up in the morning I get this poping sound that sounds like setting off a fire cracker inside of a can, it's kinda like a deep hollow sound. Someone had told me it might be a hole in the exhaust ? I'm not sure though, anyone have any ideas what this might be ?
Thanks
HISSIN50
34
129
Sep 9, 2009
  • Sep 9, 2009
A hole in the exhaust would make noise at all times.
Does it crank for a bit before it catches? Is it a backfire (afterfire)?
Do you run cats?
Does it do this while the car just idles?
Any codes?
F
fuzzyrat123
  • Sep 17, 2009
It starts right up, has a rough idle for a few seconds but when I let off the gas and acts like it wants to stall I'll hear that poping sound like someone put a maxwell can under my car and set off a firecracker( if you can imagine what that sounds like) but that's the sound I'm getting.
No backfires, don't run cats, if the car is just idleing it doesn't do it, only seems to do it when I first start it up giving it some gas.
I took my car to the local AutoZone and was told I couldn't pull the codes since my Mustang is a 90, they can only do cars 96 and up
A friend of mine seems to think I have a blown head gasket since I'm draining coolant very fast...no fuilds in the block, no leaks on the ground...only fluids hitting the ground is through the exhaust pipes.
I'm getting ready to pull the heads and I'm hoping they are still in good shape, no cracks or warpage.
93project
549
52
38
El Paso, tx
Sep 17, 2009
  • Sep 17, 2009
You're leaking coolant from exhaust? Head gasket issue....
as for Autozone not doing your codes... don't bother with them. even when they do it on new cars, EVERYTHING comes up as "bad o2". Buy a cheapo OBD1 scanner from Oreilly's and be done with it
F
fuzzyrat123
  • Sep 18, 2009
Thanks
Fog horn sound
  • brandon4v
  • Jun 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 23, 2026
squeak93
D
please help
  • dstuart
  • Sep 26, 2025
  • The Welcome Wagon
The Welcome Wagon Sep 27, 2025
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
