What could be wrong
  • Thread starter Thread starter silver87
  • Start date Start date Jul 21, 2004
silver87
115
Northern California
Jul 21, 2004
  • Jul 21, 2004
I just bought an 87 gt with 77,000 miles on the car. Just recently I have noticed it idle's extremley high around 1,500 rpm. It then drops down to around 800 rpm. This happens periodicly jumping in rpm's at idle. Also when I am shifting there is no rumbling form the exhaust when I let of the gas, it sounds like I never take my foot off the gas. Does anyone know what could cause this. I have never had a major tune up since I bought the vehicle, could it be a bad distributer or maybe could it be out of timing? Does anyone have any suggestions?
Thanks
shttygtstang
978
  • Jul 21, 2004
hows the voltage from your tb did you test it
silver87
115
Northern California
Jul 21, 2004
  • Jul 21, 2004
I have not run that test yet? I dont want to sound like a complete idiot, but do you just use a voltage meter to test it?
shttygtstang
978
  • Jul 21, 2004
yes ground on the black wire not the bat- and green if its wrong then loosen one bolt anslightly twist it it should go up an down ideal setting is .92-1.00
Q
Quick5pnt0
1,208
north eastern PA
Jul 21, 2004
  • Jul 21, 2004
Yes you need a volt meter to set the tps. Clean your IAC, and TB, then set the TPS, and clean the MAF
It's all here...
http://www.muscularmustangs.com/iac.html
silver87
115
Northern California
Jul 21, 2004
  • Jul 21, 2004
Thanks, I will try that. Would an electric fan cause any problems like this?
shttygtstang
978
  • Jul 21, 2004
that might not be it though do a tune up first show your car some love
silver87
115
Northern California
Jul 21, 2004
  • Jul 21, 2004
I've noticed that the distributer rotor needs to be replaced and I will be rplacing plugs and wires soon.
HISSIN50
34
129
Jul 21, 2004
  • Jul 21, 2004
really check out the IAB, as said. as long as the TPS is under 1.3 volts, static, the puter will zero it out. i would not sweat that too much, right now.
check for vac leaks. a stock-ish motor should have 15-20 inches at idle.
on an aside, i would hit all the maintenance items, as it sounds like you are preparing to. spend some cash and do the plugs, wires (if necessary), fuel, air, all other filters. cap, rotor, as you said. PCV, grommet, screen and all that kind of stuff. no one item may make a big difference, but commulatively, it can make a difference.
if unsure what all to check/replace, get a repair manual and check the schedule of maintenance intervals and chapter one (maintenance items, normally). mow it all down, IMHO.
oh yeah, pull codes for fun, so you know what gives (either a clean slate or you will know other things to fix down the line). sorry, im all over the place - tired.
good luck.
silver87
115
Northern California
Jul 21, 2004
#10
  • Jul 21, 2004
  • #10
Thanks, I really appreciate the help.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
T
Engine Need help figuring out misfire and backfire
  • trystancounts
  • Sep 25, 2025
Fox 5.0 Mustang Tech Sep 26, 2025
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
