whenever i turn my car off it diesels for a little bit and then sputters gas out of the carb. what can be wrong?
Lemme guess since there's not much info here...lotsa miles with no rebuild?SLEEPERstang21 said:whenever i turn my car off it diesels for a little bit and then sputters gas out of the carb. what can be wrong?![]()
Ozsum2 said:What is your timing set at and your idle rpm? Could be that both are advanced too much.
Shocwave04 said:Man.... I had this same problem... its the vacum advance. And yes hes right. Until you fix it shut it off in gear.
Ozsum2 said:Vacum advance??? Huhhhhh? Do you mean the timing is just too far forward like I said, or do you really mean vac advance?
WORTH said:To much Pot does that![]()
