what da hell..... TFI Module Question
  • Thread starter Thread starter crunchie12268
  • Start date Start date Dec 18, 2004
C
crunchie12268
599
Manhattan, KS
Dec 18, 2004
  • Dec 18, 2004
I was wondering what happens when a TFI goes bad, or what the symptoms of a bad module are. Can I notice a difference in performance if mine is bad? will it still run?
O
outlawjay
20+ Year Stangneter
Dec 2, 2004
104
Atlanta
Dec 18, 2004
  • Dec 18, 2004
I think if anything is wrong with it then it just won't work.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 18, 2004
  • Dec 18, 2004
TFI modules can quit cold and keep the car from running.
However, the most common failure mode is to start missing above 3500 RPM when warm.
They sometimes require a special Torx screwdriver bit to remove them - $5-$6 at the auto parts store. Othertimes, it's just a good 1/4" deep socket.
Clean the distrubutor mount pad good & use plenty of the white heat sink grease when you put a new one on or re-install the old one.
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
