What differential to use?
csledd
Official Ovary Punching Member
1,115
Paducah, KY
I want to upgrade the rearend hopefully this fall to a 31 spline, and I've always heard I could get a differential out of a Ford truck/suv that would work and is just as good as the aftermarket ones? Just wondering what years I need to look for because I have access to an unbelieveable amount of Ford trucks/suvs lol
you can grab one out of an explorer or something (come with 3.73 gears as well) & be set if you double pack the clutches. but if you plan on launching hard on slicks a fair amoutn i'd get an eaton posi if it were me
You can get an 8.8 out of a Ranger,Explorer,F-150 2wd. They're the same, just make sure that the clutches aren't worn out. Also, you might be able to find one with 4.10s.
P.S., they're fine for the strip and slicks!
Don't lie! :p
Just kidding lol... But i've heard Explorers and trucks would be your best bet :nice:
I you want the best bang for your buck get a set of good aftermarket 31 spline axels......go to ford and buy a good bearing kit and use and f 150 diff and install 4 new clutches into it.... (they come with 3 already).....The clutches aren't much at all about 30-40 bucks and you will have one hard hitting strong rear end.....total in parts shouldn't run more than 300-350 bucks!
"ED"
not 100% true, most Rangers still use the 7.5 rear, not the 8.8. your best bet is a F150 wth an 8.8 and look for an "L" in the tag code which denotes it as being a locker. ie: 3 L 55 or 3 L 73, 4 L 10
or we sell new ones for @$260.00
I never said EVERY Ranger, F-150 or Explorer had a 8.8 in it did I ? :Zip2:
Trust me, I know what size rear axle goes in what, a what ratio's are availiable.
GT JAY said:
That I NEVER said ever truck and SUV comes with an 8.8.
FYI I work at Sterling, so I know just a LITTLE bit about Fords axles. :)
:shrug: ok, well thats nice.....but what you said was a little mis-leading as 90% of Rangers have 7.5 rears not 8.8's so someone reading this might waste alot of time looking at rear ends on Rangers when it much easier to just grab one outta a F150 and be done wth it.
All I was saying is that if you found a wrecked Ranger WITH AN 8.8 or an 8.8 FROM a Ranger that you could use the carrier and gears!
I'm done with you!
