Just to give you a heads-up, mustangkid: the back end of the right (passenger) side will be the hardest bolts to get to. On the left (driver) side, you may have to "hold your tongue right" to slide the header down around your steering shaft.
Also, a word to the wise: disconnect your battery during the install. When I did mine a few years ago, I took the battery out. It's easy to get distracted and accidentally set a tool in the wrong place. A friend of mine leaned over the fender and accidentally knocked a wrench onto the battery--scared the s**t out of himself when it sparked. Luckily, that was all that happened.
Good luck and +1 on patience being the most important part.
