  • 1994 - 1995 Specific Tech
What Do These Symptoms Indicate..??
  • Thread starter Thread starter rude_life
  • Start date Start date Apr 27, 2005
rude_life
372
  • Apr 27, 2005
Since i got my car i have gotten it to run better little by little..but there is still some problems. I have Thoroughly cleaned the MAF Sensor, Cleaned the ACT sensor, cleaned and oiled K&N Filter, replaced the Fuel Filter, Plugs, Wires, Coolant Temperature Sensor, 02 Sensors.
Lately it seems that my car is slow to climb in RPM's and i noticed that every time i refuel my car runs better after. Another thing, as i brake (especially harder braking) for a red light or stop sign, as i stop it seems the idle nearly dies as if its struggling for fuel at that moment. She actually died for the first time this morning when i stopped at a stop sign. I changed my fuel filter about a week ago and now every time i get out of my car i smell gas. I am not sure if this has anything to do with the rest of the stuff...??
Thank you for your input .
Kris
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Apr 27, 2005
  • Apr 27, 2005
What's your fuel pressure? Your AFPR may be going. What's your timing set to? Also, do you have a check engine light? Have you pulled your codes, even if you don't have a CEL? Your O2 sensors my also be bad. Check for codes first, before you buy anything else.
94-302-vert
1,947
NE CT
Apr 27, 2005
  • Apr 27, 2005
When did the symptoms start?
It sounds like you need to run a fuel system cleaner through and like you have a fuel leak somewhere (probably around the new filter).
Chris
rude_life
372
  • Apr 27, 2005
Well i think the symptoms have always been there but like i said, through replacing all the parts i have the car has gradually started to run better, but now the problems have kind of been narrowed down to the dying or nearly dying at stops. I forgot to say i replaced the 02 sensors last weekend.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
G
Sputtering/misfiring below 2500rpm
  • Godless
  • Sep 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2025
gkomo
