What do you all think
mattch2
505
Niagara Falls
guys I need to replace my current motor and came accross this one..what do you all think?....What would you be willing to pay for this?
it is a 2000 windsor block.
with a 5.1 litre stroker kit in it
all fully forged
kellogg crank
manley h beam rods
mahle forged pistons
comp cams 270 cams
compression ratio is 8.36:1 ( made for boost )
the block was line honed
decked
acid dipped
the bores were done to exact tolerances for the pistons. ( .001 -. 003 of an inch )
the heads are stock with the exception of them being gone through to be cleaned, new valve seals, springs ( for the cams ) i had the valve seats machined, and the head was machined to be flat.
then i added a ford racing HV oil pump and pickup
and BRAND NEW timing gears,chains, tenioners, guide arms
brand new water pump
ALL ARP hardware head studs, main bolts
cometic head gaskets
