What do you think?
  • Thread starter Thread starter whiskey
  • Start date Start date Dec 13, 2010
W
whiskey
  • Dec 13, 2010
Hey guys i just joined the site, lots of great info on the forums. I'm going to test drive this tomorrow, it has high miles but i believe these 4.6's run strong and last, what should i look for while driving it any issues? He wants $6,000 do you think that's fair?
2001 Ford Mustang GT, $5,980 - Cars.com
02NutStang
17
Venice, FL
Dec 13, 2010
  • Dec 13, 2010
I would say its fair. I think its a little on the high side of what it is worth though. but watching the video definitely makes me want it now! How many miles does it have on it? and does it have maintenance records?
mransr
1,188
36
98
Riverside, SoCal
Dec 13, 2010
  • Dec 13, 2010
100,000 isn't really high mileage anymore...you should be able to get an easy 200K out of a well maintained Mustang
W
whiskey
  • Dec 13, 2010
I like that it's so clean and has the Mach sound system along with Manual trans and Convert!!! Whats the stock gears in this year GT?
Kornnut
1,999
48
108
Tulsa
Dec 13, 2010
  • Dec 13, 2010
3:27 is the gears
Is this car going to be a daily driver?
W
whiskey
  • Dec 13, 2010
I'm sorry i should have said that, it will be a 2nd car. My daily driver is a 1996 lincoln Mark 8. I will drive them about evenly, more so the Mustang cause i love driving manual.
The only plans i have for it are 4.10's (i don't drive on the highway much) and wider rear wheels/tires and the basic mods cai/exhaust etc.
I can't wait to test drive it i want to see how 1st and 2nd feel and the clutch etc. Hey even if it needs a clutch soon i think it is a nice looking car. Only thing that scares me is WHY dont they have an engine bay shot? lol.
D
Deleted member 38176
Dec 13, 2010
  • Dec 13, 2010
Looks good to me.
sneaky98gt
2,387
144
114
NC State University
Dec 13, 2010
  • Dec 13, 2010
Looks real good to me. Assuming nothing is wrong mechanically, or cosmetically, that's a pretty good deal.
roadman4.6
69
Ohio
Dec 13, 2010
  • Dec 13, 2010
Seems cheaper than anything else listed in Autotrader for your area. Cheaper than all of the private listings, but most have less miles. I would make sure they provide a car fax report. It seems the Honeycomb rear panel is painted silver, I thought these were normally black. May have painted for appearance though. Just me, but I prefer to buy off a private owner vs. a dealer. They may be just trying to unload this for the winter. Also depends if you can do the repairs yourself if anything comes up vs. taking to a shop. Just some things to think about, I would look at more than one before you buy anything. Looks clean though - good luck!
erichmess_
Member 4 Life
6,836
10
79
Miami
Dec 13, 2010
#10
  • Dec 13, 2010
  • #10
I had a 01GT that had about 115k miles on it. I was constantly having little mechanical problems. No major problems at all, but the cost of keeping her running was starting to add up. Just saying.
02GTRX
I told an admin to shut up...now I live with the S
20+ Year Stangneter
Sep 27, 2004
213
#11
  • Dec 13, 2010
  • #11
If you do get it definitely get 18" fr500's and lower that 4x4 atleast 2 inches! And tint!
T
Tomtom9401
60
#12
  • Dec 13, 2010
  • #12
Hey man, looks like a sweet car, i hear the mustang can be fairly reliable for many miles if properly maintained. The car looks like it has a few little customizations than add extra detail and may save you some money if planned on doing any of that yourself. It does look like the rear honeycomb panel between the tail lights is painted it also looks like it has a chin spoiler that is painted silver as well on the front bumper. I thought that these parts were a type of ABS plastic, i may be wrong but not sure if they were designed to be painted. I would check it out the paint make sure it was quality work. Ill also give you a few tips to looks for, just little things that i have gathered vigoursly reading forums since 2 weeks ago when i bought my first stang hehe. First is the transmission, there has been quite a few threads on the matter and a few different experiences. I believe this is the first year of the Tremec 3650 transmission and they have a notorious issue from the 1-2 and 2-3 shift. They have released a few TSB's some people say that the revised fluid level helped solve their problems but they have also designed upgrade for the syncros, shift forks ect.. So unless the transmission has this upgrade i would not be afraid to get on the gas a little and try shifting above 3500 RPM's to make sure everything feels good. It may lead to future problems, ask the dealer and see about some type of warranty on it. Your car may have the t45 transmission, check out the VIN to see what type of transmission you have i believe they switched to the 3650 mid year in 2001. Carfax should list if the transmission has been serviced. Aftermarket shifters, if the car has one, also may cause damage to the transmission if the shift stops on the shifter are not adjusted properly, there is a TSB on the matter, if it has an aftermarket shifter i recommend removing the shift stops. Another problem i have been reading up on, is the spark plugs. The aluminum heads of the 4.6 have been known to blowout spark plugs if not installed properly on a cool engine, with a car of this mileage i would assume they have been replaced before, if not, then they probably are due for a tune up. I would try and take it to a mechanic and see if it has had any work done to the spark plug threads, they usually add a sleeve into the head to allow you to install the spark plug properly. If it has had this type of work, its hard to tell if the piston was damaged, or what kind of damage it may have caused when it blew out. Then again it may have been serviced properly and there has been no damage done at all to the car. Those are the only 2 main things about this model Mustang that i have noticed from reading around on the internet. other than that its a great car, i am in love with mine. Im not sure what your gas mileage is like on your previous car but be prepared to shell out some gas money, even more if you are gonna be installing gears hehe, it was a bit of a suprise for me, even after daily driving my lifted chevy 1500 on 35's haha. That is unless you are planning on driving like a little girl lol. They are good cars, very fun to drive, especially if you dont drive stick regularly, this is my first stick car and it makes the car twice as fun. Good luck and sorry for the ginormous paragraph haha
T
Tomtom9401
60
#13
  • Dec 13, 2010
  • #13
Also, i will agree with Roadman4.6 in that i would def. not be in a hurry to purchase the first Mustang that you see. Keep your eyes open and be patient there are a lot of these cars out there, i usually see a new one posted on Craigslist every other day. Ofcourse if it is a good deal on the price ect... for your area, dont be too hesitant on buying it i missed out on a couple of steals that i could have had when looking around. I wouldnt give more than 500-1000 more than what you think you could sell it for the next day if you decide to.
W
whiskey
#14
  • Dec 14, 2010
  • #14
Thanks a ton guys!!! I'll let you guys know tomorrow.
d98gt
4,505
59
204
SE Texas
Dec 14, 2010
#15
  • Dec 14, 2010
  • #15
Wow..that was a long post but did contain some good information.
W
whiskey
#16
  • Dec 14, 2010
  • #16
Man what a waste of time, she looked so good in person till i popped the hood. There was green writing all over the front of the engine ans all parts in the engine bay, either it was in a huge front wreck or had the engine replaced. It didn't help that there was oil dripping from various areas also and the oil looked like chocolate milk (NOT GOOD!).
Thanks for the advice though guys, my quest continues for a nice Stang.
N8Dogg98
3,872
238
184
MN
Dec 14, 2010
#17
  • Dec 14, 2010
  • #17
That's weird.. they used green paint for the cash for clunkers program...
9
96SVTKB
42
North East Fl.
Dec 14, 2010
#18
  • Dec 14, 2010
  • #18
Sorry to hear it didn't work out. Just keep looking, there are some good deals out there. The 4.6 is a great engine, this is my third one with the highest milage being 175k on a 96 gt. I drove that thing hard and it ran great when I sold it. Its all about the routine maintenance.
erichmess_
Member 4 Life
6,836
10
79
Miami
Dec 14, 2010
#19
  • Dec 14, 2010
  • #19
Wow that really sucks. At least you found out before you bought it. Good luck with the search!
BTW, what kind of budget do you have for a Mustang?
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Y
2004 Roush - Dome Lights and radio not working
  • Yurei
  • Nov 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 20, 2025
squeak93
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
