  • SN95 V6 Mustang Tech
What does this part do?
  • Thread starter Thread starter 69gmachine
  • Start date Start date Mar 29, 2010
69gmachine
576
Southern Maryland
Mar 29, 2010
  • Mar 29, 2010
I was browsing ebay when I found a 99 up 3.8 longblock for sale. There was a tube that ran down the middle of the lifter valley in the picture. My 96 3.8 doesn't have this tube. Can anyone tell me what it does? Do I really need it?
thanks in advance for any help
MustangLX-5.0
856
Lehigh Acres Fla.
Mar 29, 2010
  • Mar 29, 2010
Not sure less I see it. Do you have a link?
shine1stang
30
  • Mar 29, 2010
if its what im thinkin of its a balance shaft to reduce harmonic vibrations, added when the switched to internally balancing
69gmachine
576
Southern Maryland
Mar 29, 2010
  • Mar 29, 2010
Yep, that's what it appears to be. A friend gave me a complete 3.8 from an 87 T-bird to use as a parts bin. I tore it down and it has the counter balance shaft like I saw in the picture.
The Mustang engine was put together by a kid. He wasn't able to get it running which is why we got the car for cheap. He had used the wrong heads, so I'm not surprised he left something out like that. It looks like it comes out the front through the timing cover. Will I need to remove the timing chain to get it out?
69gmachine
576
Southern Maryland
Mar 31, 2010
  • Mar 31, 2010
Well this just keeps getting more interesting! My mystery motor never came with the counter balance shaft. There are no oil holes drilled for the bearings and the timing chain sprocket has a spacer behind it where the helical gear would be that drives the counter balance shaft.
There is a "3.8" cast into the lifter valley but is it possible that it's actually a 4.2?
Also, if you're not already aware, there is a "gotcha" on the front timing cover. The moron engineers at Ford that designed this thing buried a hex head bolt on the lower driver's side corner. I cracked 2 timing covers before I saw the little hidden bolt. Now I have to find another timing cover. I'm really starting to hate this little engine
D
Help--Need New Exhaust Gas Recirculation (EGR) Tube for 1994 V6 3.8 L Mustang--where can I find one?
  • DPP
  • Jun 5, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 10, 2025
DPP
D
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
C
Fuel 01 mustang coup 3.8 looking for help with finding a schematic , fuel level sensor
  • Chipstack8
  • Sep 7, 2025
SN95 V6 Mustang Tech Sep 8, 2025
Chipstack8
C
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
