What Fan Controller
  • Thread starter Thread starter rustyruststang5
  • Start date Start date Sep 28, 2012
R
rustyruststang5
151
Ne
Sep 28, 2012
  • Sep 28, 2012
what do you guys use? im using a spal on one of my cars and really like it but i cant seem to find one for sale at a good price. so im looking for other opitions.
boostfrk
712
69
59
Colorado
Sep 28, 2012
  • Sep 28, 2012
A lot of people have had good luck with Delta Current Control, www.dccontrol.com
R
rustyruststang5
151
Ne
Sep 28, 2012
  • Sep 28, 2012
does that company have a number.
HotFox
1,058
672
164
SE Michigan
Sep 28, 2012
  • Sep 28, 2012
DCC works for me, had to use bolt eyelet instead of probe because of aluminum radiator. No problem after one year. As far as I know they don't have a phone number.
Scott
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Sep 28, 2012
  • Sep 28, 2012
DCC would probably be the best option but the most expensive too. I had a thermostatic switch that threaded into the hole that is pluged on your thermostat housing and would turn the fan on at a certain temperature. Pretty basic setup, nothing fancy, but it was cheap.
You will need to wire it to a high amp relay though.
http://www.summitracing.com/parts/DER-16749/
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 28, 2012
  • Sep 28, 2012
What fan are you using? If it is the MKVII or Taurus fan you need to use a VSC controller that has soft ramp up vs. other controllers where the amps will spike upon startup.
+1 on Baskin's DCC controller. The best out there but expect to wait anywhere from 2-6 weeks for one. If you can't wait, then get the FAL 33054 from Summit. Do NOT cheap out on the controller. Spend the $100 and do it right the first time. It is far more expensive to do it right the second time or fix your car when you overheats from using the cheapo controller. I have a Taurus 2 speed fan and DCC waiting to go on my car.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 29, 2012
  • Sep 29, 2012
DCC controller with a Taurus fan and stock thermostat here. Works great. No cooling issues. Simple design, well built. Would recommend to anyone.
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
F
Fox 1988 GT Lumbar controls not working
  • Fcortes795
  • Mar 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 7, 2026
AeroCoupe
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
