What gear oil??
  • Thread starter Thread starter Rockin302
  • Start date Start date Nov 10, 2004
First Prev 2 of 2
Rockin302
236
California
Nov 11, 2004
#21
  • Nov 11, 2004
  • #21
uh oh, what if i dont have access to a torch?? Heat it up with a BBQ lighter??? Anyone try putting a little anti-sieze on the threads after the fact?
HISSIN50
34
129
Nov 11, 2004
#22
  • Nov 11, 2004
  • #22
i would try loosening it first. i have not had to torch any out. just make sure the ratchet is on square and deep and give it a try.
a small amount of anti seize should not hurt.
good luck.
Rockin302
236
California
Nov 11, 2004
#23
  • Nov 11, 2004
  • #23
will do! I have a long breaker bar so hopefully that will do the trick.
46defense
445
Sanford Fl.
Nov 11, 2004
#24
  • Nov 11, 2004
  • #24
Everyone has access to a torch. Just go to Home Depot and pick up a propane torch kit for $10-$20 They come in handy more often than you would think.
M
macx
228
SE Missouri near Cape Girardeau
Nov 11, 2004
#25
  • Nov 11, 2004
  • #25
An impact will often loosen things that a
hand wrench/breaker bar won't.
If you have problems getting the plug out, apply some penetrant to the plug a couple times a day for a couple days and try it again.
Synthetics are good because they stand up to heat and extreme pressure in bearings and between gear surfaces better and have more additives. Many heavy truck owners and fleets went to them because the differentials and trannys last longer and they get a tad better fuel economy, and those guys are often putting well over 1,000 lbs of engine torque thru the trans, then multiply that by the trans multiplication for the rears.
Synthetics usually flow into the smaller spaces better so lube better because of that, too, as well as flowing better when cold.
Rockin302
236
California
Nov 14, 2004
#26
  • Nov 14, 2004
  • #26
Bought some Redline 75W-90 Gear oil with the friction modifier and will be changing it sometime in the next few days. I guess I'll go with the Permatex copper RTV since I've heard a couple good reviews about them. I saw the blue and black RTV stuff as well, prob shouldstay away from those? Hope I have luck with the fill plug, everything else seems to be fairly easy.
HISSIN50
34
129
Nov 14, 2004
#27
  • Nov 14, 2004
  • #27
i use the copper myself (not sure if i said that before). i dont recall all the specs, but it seems to be resistant to more things than some of the other 'colors'. i could be wrong on that - just my recollection.
sounds like a good plan. i bet it goes super easy. BTW, for filling, if i did not touch upon it, what i like to do (there are many other methods): i have some clear tubing from the home store. i run it from the filler hole, up over the left rear tire. then i pour from outside the car (as opposed to be under it). works for me (gravity feed). just keep an eye on the level. pumps are supposed to work well too.
good luck.
87gtconv
ragtopman
2,595
Southern Calif
Nov 14, 2004
#28
  • Nov 14, 2004
  • #28
Isn't Synthetic (Redline) 75W90 gear oil what should be used??
Rockin302
236
California
Nov 14, 2004
#29
  • Nov 14, 2004
  • #29
Thanks Hissin and all. Oh, I'm going to fill it with the syringe method. Might be a bit slower that way.
One last thing, cure time for the RTV? An earlier post said to wait a day but RTV should be good after about an hour right? I don't plan on driving the car after the oil change so I hope there aren't any issues with the gear oil mixing with any uncured RTV.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 14, 2004
#30
  • Nov 14, 2004
  • #30
For just a few bucks at the parts store, you can usually buy a small hand pump that screws into the lube bottle. Mine works exceptionally well. I've also used Hissin's method many times - funnel into a tube outside the car. Just clamp the hose so that it doesn't pull out of the case unbeknownst to you as you continue to pour the first quart all over the ground. Don't ask....
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Nov 14, 2004
#31
  • Nov 14, 2004
  • #31
I did it the other way for many years and it works fine, and then I spent a few bucks on a pump and I'll never go back.
Mine is actually a self-contained pump -- looks like a grease gun, except you unscrew the top and pour whatever into it. Then you pump it like a grease gun out of the tube it has attached to it. Michael's sounds a little cleaner, but I like mine as well.
You'll find other uses for it too -- works well on filling manual trannies, etc.
HISSIN50
34
129
Nov 14, 2004
#32
  • Nov 14, 2004
  • #32
Adam, interesting. the reason i dont use a pump is that the pump i have never seems to fit the bottles i have. i think my pump is from the old days with bottles that had bigger mouths.
good idea though. where do you get it and how much? i never looked at a parts store for one.
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Nov 14, 2004
#33
  • Nov 14, 2004
  • #33
Mine is from AutoZone -- in the grease gun section. I think it was around $10 as I recall.
HISSIN50
34
129
Nov 14, 2004
#34
  • Nov 14, 2004
  • #34
Adam, thanks for the info.
Rockin302
236
California
Nov 14, 2004
#35
  • Nov 14, 2004
  • #35
Got the car on jacks right now and the gear oil is flowing out as I speak. I've cleaned off all the old gasket material off the cover and most of the stuff on the housing. Going to wait till tommorrow to get the RTV( the Permatex copper stuff) and re-fill with the Redline gear oil.
Interestingly, the fill plug was a snap to take out. It just had a little bit of thread lock on it. I was all worried about nothing!!
thanks again for everyone's help!!
Rockin302
236
California
Nov 16, 2004
#36
  • Nov 16, 2004
  • #36
Boy, gear oil sure stinks but I got used to it after awhile, quite pleasant.
Took me like an hour to pump the damn oil in. I used a syringe with a 2 oz. capacity and laborously pumped it in. If I could only get my hands on a peristaltic pump!!!
I sped up the curing time for the RTV by hitting it with a hairdryer. So far so good, no leaks yet!!
HISSIN50
34
129
Nov 16, 2004
#37
  • Nov 16, 2004
  • #37
sounds good. gotta love the smell of that stuff, huh.
in the old days when i used a pump, it still took forever to get gear oil to pump, esp if it was cold out. sounds like newer pumps (and smarter people) have an easier go of it. im gonna check out one of those pumps like Adam described. otherwise, my clear plastic tubing works good. when i did the camaro's gear oil, i hung the funnel (with hose attached) from a bungee off the garage door bracing. talk about easy.
i have RTV'd and filled within an hour before and it was fine. i think as long as the pumpkin cover doesnt flex before it cures, the stuff should be alright (Michael, Adam, et al, will know better).
nice job.
First Prev 2 of 2
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
New guy- first Stang- I love it !!
  • smid333
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2026
smid333
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
