What headers>?
  • Thread starter Thread starter allcarfan
  • Start date Start date May 12, 2004
1 of 2 Next Last
allcarfan
The Answer Man
2,458
North Atlanta
May 12, 2004
  • May 12, 2004
I am building a street car that MIGHT see a trip or two to the track. setup as follows:
completely forged 347 -ross pistons, hbeam rods, etc
CNC stage II ported TW heads
Ported Edelbrock RPM intake
speed demon 650 carb
1.6 cobra roller rockers
XE274HR cam shaft
(should be making darn close to 500hp NA)
C4 Trans - race prepped
Reverse Manual VB
TCI 3000-3500 stall
Transbrake
Rear is a Mach I 9"
Rebuilt with auburn 3.50 gears.
Exhaust
2.5" drgas Xpipe
Hooker aerochamber muffs
2.5" polished ceramic coated tailpipes
Now....
What size header primary should I be using? 1 5/8 or 1 3/4?? Most combos like this I READ about say 1 3/4"...but id like to hear some other opinions
Shane
L8knight
52
Chicagoland
May 12, 2004
  • May 12, 2004
When in doubt, go big!
Seriously, I'd go with the 1 3/4... but that is not based off anything other than my preference/opinion.
Edbert
3,548
32
109
Austin TX
May 12, 2004
  • May 12, 2004
I think you've got enough cubes to provide torque, that you can make a go with the 1.75s.
Usually they also are used with 3" pipes rather than your 2.5s, but I think you'll be breathing deep enough for it to not be a problem. Just my opinion of course...YMMV ;-)
F
fastcoupe68
368
nj
May 12, 2004
  • May 12, 2004
Go with 1 3/4 the smaller 1 5/8 will just choke down the combo you are using.
allcarfan
The Answer Man
2,458
North Atlanta
May 12, 2004
  • May 12, 2004
Damn....das gonna be $700 for headers
ratio411
3,870
73
109
Pensacola FL
May 12, 2004
  • May 12, 2004
1.75" headers... do they make torque steps for your application?
Off topic:
IMO you are using the wrong intake.
You have plenty of parts going for torque, the intake on this combo should be able to breathe. My experience with the RPM is that it falls off after 3k rpms compared to a mild single plane intake. Not that it won't spin or make power past 3k, but it gets increasingly choked down while SPs go up-up and away. Below 3k, it has a little more torque, but it is not as dramatic as some would believe, assuming you use a mild SP intake. Besides, you are going to use a 3k stall converter! Why not use an intake that operates best after 3k instead one that falls off in comparision?
Just a comment from experience...
Good luck
Dave
allcarfan
The Answer Man
2,458
North Atlanta
May 12, 2004
  • May 12, 2004
Ratio,
The RPM intake has been ported, the ports will be port mathced as soon as I get my heads and the runners have all been smoothed out. It flows a lot better than a normal RPM intake Thanks for your input!
I might use a ported weiand xcelerator if I can sell the RPM. I had to repair the water inlets onthe RPM, works perfectly, but im sure no one will buy it.
washMO66
1,000
Washington, MO
May 12, 2004
  • May 12, 2004
I will tell you from very recent experience and a very similar set up that I have (see below). I had a port matched performer RPM and the car ran a best quarter of 11.70 @ 115 on slicks last year. Low end torque was awesome and I thought the car could not run any better but it seemed to not have the grunt up past 5400RPM, it would pull, but I was not satisfied. SO I went to my local speed shop and went over my build with the owner and ask him what he thought the motor would do with a Vic Jr, when I showed him my documented flow charts of my heads he said I was not getting near the full potential out of my motor and he INSISTED that I do the single plane. Extensive port matching and a few jet adjustments and holy moly, it's like I have a new engine. This thing pulls so hard, and yes even from idle, up top it is insane how much harder the car pulls. Streetability, yep, because I do drive it on the street a couple times a week.
Friday I am off to the welder to put in the new 6 pt cage and harness. I haven't raced yet this year but based on how it's running and even with the extra weight of the cage I would bet my last dollar that I will pick up a good 3 to 4 tenths and probably 4 to 5 more MPH through the 1/4. I could kick myself for not doing a single plane from the start and now I am truely re-evaluating my carb size, although the mighty demon 650 supposedly flows 753 wet. Good luck. Oh, and the headers I have are 1 5/8 w/ 3" collectors. Hooker super comp ceramic coated.
347ci
Comp Cams aluminum 1.6 roller rockers
Mighty Demon 650
Lunati Crank, Lunati street / race rods
KB flat domes w/ 6.5cc reliefs
Probe girdle
Comp cam XE274HE Xtreme Energy roller Cam Duration @.050 224 – 232, valve lift .555 - .565, lobe separation angle 112 degrees
AFR 185 heads ported and polished by Joe Mondella (documented flow charts)
Victor Jr SP intake
Hooker super comp ceramic coated long tubes
Weiland aluminum water pump
Elgin high volume pump
Holley blue fuel pump w/ regulator
MSD 6AL, blaster 2 coil
Currie 9” w/ 3:70 Detroit true trac
TCP Uppers w/ 620 Mustangs Plus 1” coils
5 leaf rear leafs
Sway Bars (front removed)
TCP Sub-frame connectors
TCP Solid Motor mounts
2500 Stall, C-4 Tranny
10.8:1 COMPRESSION
allcarfan
The Answer Man
2,458
North Atlanta
May 12, 2004
  • May 12, 2004
u dont think those headers are holding u back?
allcarfan
The Answer Man
2,458
North Atlanta
May 12, 2004
#10
  • May 12, 2004
  • #10
I dont know if a Vic Jr Intake would fit under a gt350 hood on a 347 in a 66 stang....anyone?
What about a weiand xcelerator?
washMO66
1,000
Washington, MO
May 12, 2004
#11
  • May 12, 2004
  • #11
It's hard to say, in my 66 coupe the fit was tight with the 1 5/8, not sure if the larger would have been tighter.
The car runs so well I really don't know. It's going to be pulled after this season and I think I am going to go to a Basic Dart or World block, change the slugs out and drop the compression a few points and go to a pro-charger to force some air. I'm addicted to more HP........
ratio411
3,870
73
109
Pensacola FL
May 12, 2004
#12
  • May 12, 2004
  • #12
I am glad someone else has been there/done that...
Folks are brainwashed against SP intakes nowadays.
I did the opposite of your story...
I ran an SP intake forever, then the RPM came out. The guy at my speed shop insisted that I would love the new intake because I would gain bottom end without losing top. He bought Edelbrock's marketing, or just used it to sell me an intake.
Man, it killed my engine. I gained a miniscule amount of low end, 2000 to 3000 felt the same, after 3000 the car felt increasingly choked off. It was really sad.
Needless to say, after 2 weeks of experimenting with porting and spacers, the intake got gone.
Dave
washMO66
1,000
Washington, MO
May 12, 2004
#13
  • May 12, 2004
  • #13
not under a stock hood but under a GT 350 hood it will. That's what I have on my 66 coupe. I have a full size edelbrok triangle air filter and the wing nut just barley peeks out if you look into the scoop.
ratio411
3,870
73
109
Pensacola FL
May 12, 2004
#14
  • May 12, 2004
  • #14
The Xcellerator is about the mildest SP I have ever seen.
The Torker 289 is a little better IMO and fits the same as the RPM.
The Torker 2, or Torker 302 is a low rise SP and would fit well. It has a large plenum and low runners though, I have never bothered to try one. It is more radical than others I mentioned, but not as rad as the the Victor.
Some other mild SPs
Port-O-Sonic
Holley Strip Dominator (out of production)
Torker 289 is out of production, but is my personal fav.
Sorry we go so far off topic.
This is just a subject I have strong feelings on.
Dave
allcarfan
The Answer Man
2,458
North Atlanta
May 13, 2004
#15
  • May 13, 2004
  • #15
No problem dave...I will just start a new thread....!!!
thehueypilot
1,084
Medina,Tennessee
May 13, 2004
#16
  • May 13, 2004
  • #16
What difference do you feel (seat of the pants) on the street using a single plane vs. duel plane? Has anyone tried the torker II on a 351W?
F
fastcoupe68
368
nj
May 14, 2004
#17
  • May 14, 2004
  • #17
With the cubic inches you are sporting there is only one intake I personnally would use, the vic junior. I would say on your combo you would see dramatic results. I am suprized that was not your choice from the get go. Change your intake!!! If you dont like the results I'll buy it from you!! Shame on CHP for not recomending the vic jr.
thehueypilot
1,084
Medina,Tennessee
May 14, 2004
#18
  • May 14, 2004
  • #18
Actually the mustang magazines filled me with their propaganda and scared me away from a single plane on the street. CHP did recommend the victor jr, but I decided I wanted better street manners. Why does a single plane effect a vacuum? I thought it was more the cam design than the intake design.
ratio411
3,870
73
109
Pensacola FL
May 14, 2004
#19
  • May 14, 2004
  • #19
Long story, I'll try to be short:
The runner diameter/length and the plenum volume have a big effect on how fast air can be accellerated into your engine.
Air velocity is lazy when the engine breathes through large ports or draws from a large plenum. It is good for volume, but not low rpm velocity, where you need vacuum.
When the engine draws air through smaller ports, the air velocity/vacuum is high, but the small ports limit flow at higher rpms.
The plenum volume not only affects vacuum, but affects throttle response and carb efficiency at low rpms. The carb gets less monitoring signal from the engine with a large plenum, so a large fuel shot is needed to keep from bogging off idle, but at high rpm the engine has a large 'reserve' area to draw from and keep the a/f mix more consistent between cylinders... So, there are intakes with small ports, small plenums or small ports and large plenums, and so on, along with varying runner lengths...
This shows the many different stratagies of manifold makers and the many tuning varieties available for about any combo under the sun. These are all things to take into account and can decrease or magnify a cam's effects on an engine.
I hope this made sense!
Dave
allcarfan
The Answer Man
2,458
North Atlanta
May 14, 2004
#20
  • May 14, 2004
  • #20
sure wish I knew if a vic jr would fit under a gt350 hood with a cobra oval air cleaner ;(
1 of 2 Next Last
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
C
experienced engine builders chime in
  • Cclaro
  • Oct 4, 2021
  • 1994 - 1995 Specific Tech
  • 2 3
6K
1994 - 1995 Specific Tech Oct 16, 2021
Shawn_Mc
Exhaust What ever happend to Tri-Y-Headers?
  • geoklass
  • Jan 1, 2019
Fox 5.0 Mustang Tech Jan 1, 2019
geoklass
T
Fox No Boost And Stumped
  • TWEECD
  • Aug 12, 2017
  • 2 3 4
13K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2017
TWEECD
T
A
  • Locked
Expired 1989 Notch
  • A46thedoctor
  • Aug 6, 2014
4K
Fox Body Mustangs For Sale (1979-93) Feb 24, 2015
BlakeSB
