what heads for a 86?
streetyme
34
I have a 86, and cant decide if I want to rebuild a different block or just use the motor thats in the car... I know the 86 have flat tops and the Trick Flows will work are there any other heads that will work with not having to fly cut the pistons?
If you're replacing your stock heads, you could remove the valves and use them as a guide to flycut the pistons yourself without worrying too much about damaging the valve guides. Isky sells a tool to do it (prices aren't listed on their website), where you just put the tool in the head, put the head on, chuck the thing in a drill, and go to town. One word of caution though, take your time if you choose to go that route. I've read they cut pretty quickly. Here's a link to Isky's website where they're listed:
http://www.iskycams.com/iskycategory_search.php?sub_category_id=133
No prob. It's probably not encouraging news to hear that you'll need to notch the pistons, but it'll be worth it in the long run, if you decide to go that route. You'll probably be leaving a good bit of power on the table if you choose to run a small cam in order to clear the pistons.
Thanks for the replies.... Looks like a might try fly cutting , and you right my scare was taking off too much... It sounds like with the ISKY tool it goes down to a preset depth..
