What heads for my combo?
  • Thread starter Thread starter 91foxbod50
  • Start date Start date Aug 2, 2009
9
91foxbod50
486
  • Aug 2, 2009
I'm looking for a set of heads for my combo, heres my mods that are going on the car as soon as i figure out what heads i should run.
cobra tubular Upper Lower Intake
Novi 1000 sc
255 Fp
34 pound Injectors
BBK long tube headers
BBK O/R H PiPe
Mac Catback
355's
Block And Ignition Stock
Drag Suspension kit
I know its not much of a combo list but I wanted to go through you guys first to see if you can come up with the best heads for what i'll be running. Will i see good results from the combo?
I just want a set of heads that can be thrown on without notching pistons.. I heard of a guy that sells trick flow heads and before he lets them go he ports and polishes upgrades the springs and rebowls them.
Thanks in advance
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Aug 2, 2009
  • Aug 2, 2009
Dump the 34 lb injectors in favor of 42's or 60's.
TFS or AFR 165's offer similar performance out of the box, so you couldn't go wrong with either one. I don't know anyone off hand that sells ported TFS heads, aside from Total Engine Airflow, but I also believe they do AFR heads, too.
strtrcr50
Previously from Dirty Jerzey exit 7a
Aug 2, 2009
  • Aug 2, 2009
Fox Lake also sells them pre ported.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
Engine An engine building combo with stock Speed Density (SD) system
  • Mcmahst
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 15, 2025
Mcmahst
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
