  • 2.3L (N/A & Turbo) Tech
what hp
  • Thread starter Thread starter palemall
  • Start date Start date Sep 8, 2006
P
palemall
18
  • Sep 8, 2006
what horsepower would i make on an na if i did a ranger header and roller setup also any thing else i can do to make power im shooting 130-150 and remotely streetable
Dr_EluSivE
2,155
Central Illinois
Sep 8, 2006
  • Sep 8, 2006
what year car are you starting with? the 90-93's already have the roller cam, you might see 3-4hp gain with a header.. probably not much though.
Dr.
P
palemall
18
  • Sep 8, 2006
sorry 89
Shawneebear93
20+ Year Stangneter
May 4, 2004
518
17
49
Salisbury Twp, Allentown, PA
Sep 8, 2006
  • Sep 8, 2006
Ranger roller cam, ranger header, and an air intake may get you up 100ish, and that's not even at the wheels.
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Sep 8, 2006
  • Sep 8, 2006
A 12+ hp gain? Please, that's laughable.
Shinlee
146
  • Sep 9, 2006
um, WHY the hell would you put a ranger roller cam into the car in the first place if you DIDNT expect a 12 hp gain just from the cam alone. sry, i work on bigger engines and such, and when i put cams in i am expecting a 25+ gain, but if the ranger cam cant even offer up 12 with the addition of the exhaust manifold/intake, wtf is the damn point of people doing the swap at all? i just dont get it.
my 105 stock car with intake/chip/exhaust/ranger header has 123 at crank right now, and i WAS thinking of a ranger cam, but your comment deters me. I'd just like to hear your reasoning behind your comment, and if i am offensive in anyway towards you, then i apoligize ahead of time.
BELL
722
California
Sep 9, 2006
  • Sep 9, 2006
may i ask why you have a intake/chip/exhaust/ranger header on a 105 hp(stock) car anyway? 18hp from all that doesnt really make much sense either. however I'm used to working the same engines but with a turbo's.
Shinlee
146
  • Sep 9, 2006
because its all a slow work in progress, as i said above, i want to do a cam swap, i am also planning on a full head port, all this is something i can do to the car, and not make me lose the vehicle for a month.
a turbo swap is just a bit outta my league atm, maybe next summer or something
Shawneebear93
20+ Year Stangneter
May 4, 2004
518
17
49
Sep 9, 2006
  • Sep 9, 2006
Red LX - I'm an eternal optomist.
Shinlee - If your car has 105 stock horsepower, it is a '91-93, no? If it is, it has a roller cam stock.
Shinlee
146
#10
  • Sep 9, 2006
  • #10
thanks teal, i was under the impression a 97 ranger cam was still slightly more aggressive than mine.
well, guess that means i just have to buy a stage 2 cam then
Red_LX
73
129
Sep 9, 2006
#11
  • Sep 9, 2006
  • #11
For some reason, over the years, after the 2.3 turbo people started retrofitting ranger cams to their engines (mostly for the reduced wear I guess), everyone else has decided that ranger cams are an upgrade. However they have the same grind as the stock cam, so you're just getting negligible gains from the reduced rolling resistance of the roller cam.
Even a fairly aggressive cam isn't worth much on an n/a 2.3L. Just the facts of life there.
BELL
722
California
Sep 9, 2006
#12
  • Sep 9, 2006
  • #12
red lx i would agree to a point. when i put the big valve head onto the 84 svo's curent engine i installed the roller due to spring pressure as it uses much larger springs (small block chevy if i remember i'll take pics from the one i just got back from the machine shop). spring pressure and more flow from the head (1.89 ex and 1.59 intake and full porting, ie regroud bwls on th head intake and exhaust ports) warrants using a roller style cam. Due to increased flow from the ( a known restriction) head and a roller style cam will allow a slightly higher rev limit, and a slight increase in hp. www.powerheads.com does excellent work BTW
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 5:48 PM
from6to8
D
4.6L 4v motor swap
  • DangStitches
  • Jul 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 29, 2026
squeak93
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
