  • SN95 4.6L Mustang Tech
What If
  • Thread starter Thread starter bigbird04
  • Start date Start date Jun 13, 2012
bigbird04
106
Decatur Al.
Jun 13, 2012
  • Jun 13, 2012
Save the forced induction . Thinking about doing LTs,throttle bottle, and plenum. Is it worth it.
D
Deleted member 38176
Jun 13, 2012
  • Jun 13, 2012
TB and plenum won't net you much.
LT's (depending on the rest of the exhaust) could get you 15-20rwhp......but would cost about $800-$900 (maybe more) including labor.
So, you would spend about $1200-$1300+/- for about 25rwhp.
03_TrueBlue_GT
810
41
29
Houston, Tx
Jun 14, 2012
  • Jun 14, 2012
He could save some money by doing it himself. What about suspension mods, or are you interested in gaining HP?
Rejekt
546
Raleigh, NC
Jun 14, 2012
  • Jun 14, 2012
I hear LT's are a major pain in the ass to install. Most people end up dropping the K member.
bigbird04
106
Decatur Al.
Jun 14, 2012
  • Jun 14, 2012
Thanks guys, I could do the labor myself . I did my own gear install ( I'm a mechanic by trade )
Basically the only thing on a car I would be scared to get into would be an automatic tranny. I was thinking the long tubes would be more of a supporting mod for a vortech kit down the road. Currently I have an offload x pipe to some weld in flows. For suspension I have cj pony parts 2 inch springs, bbk caster camber plates,and mm full length subframe connectors. Believe it or not the car hooks pretty good on the nitto 555s. So I don't really know if I wanna do more suspension parts at this time . I'm open to suggestions ! I thought the TB and plenum might be a waste, but they are just so easy thought I might try. Maybe do headers and cams instead ? I don't want to spray it at this time because if I got every thing I wanted for a nitrous set up , I would like about 1500 doing a vortech kit ( kit tune bottle heater remote bottle heater ect )
1fun281
438
Atlanta Georgia
Jun 14, 2012
  • Jun 14, 2012
Longtubes would compliment a vortech greatly, also longtubes are worth every blood sweat tear and penny, they give the car such a grunt definetly a must even to a stock car
demented22
222
pittsburgh, pa
Jun 14, 2012
  • Jun 14, 2012
I am interested in this also. What brands LT's work best? I was just looking at macs. My next question is what about clearance? I have read if your lowered they hit. My prochamber hits now lightly every now and then. I did help a guy a couple years ago put on a set of equal shorties. It was a pita! Is there a write up on long tube install anywhere? I am also a mechanic. but on construction equipment. I will be doing this on jack stands also. My idea is I need to replace my transmission soon. So I figured while it was up, it would be a good time.
D
Jun 14, 2012
  • Jun 14, 2012
MAC is u at the top. I run a full MAC setup (LT's, mid-pipe, catback) and couldn't be happier. I am lowered almost 2" and clearence is a concern. I've had th LT's for long enough that I am able to judge whether I will clear or not just by looking. You learn to take speed bumps VERY slowly (and at an angle if you can). Honestly, clearance isn't a problem anymore. Im not sure if there is a write-up anymore, but an LT install is pretty straight-forward and easy......it's just a complete pain in the arse! I did mine with floor jacks, an engine brace, and dropping the K-member (easiest route).
demented22
222
pittsburgh, pa
Jun 15, 2012
  • Jun 15, 2012
Thanks! We are supposed to close on our house mid July, then I will finally have my garage. Sounds like I will make a go at this. Now I am preety sure I have read that Lts need to be removed to pull your trans, but not all need to. Do the Mac's?
3,287
24
69
Broke
Jun 15, 2012
#10
  • Jun 15, 2012
  • #10
I didnt notice anything with plenum and TB. Skip that IMO.
bigbird04
106
Decatur Al.
Jun 18, 2012
#11
  • Jun 18, 2012
  • #11
Thanks I was thinking I would be better off with out for now. I want macs but the ceramic pacesetters are very tempting. I am thinking of giving them a try.
bigbird04
106
Decatur Al.
Jun 18, 2012
#12
  • Jun 18, 2012
  • #12
Macs do not have to be removed is my understanding. Not sure about pacesetters. ( I've had them on ls1s, (fit great, buy the way I've also heard horror stories on gts). I just want my LTs to fit right the first time with little or no mods to k member, floor pans, or stearingshaft.
03_TrueBlue_GT
810
41
29
Houston, Tx
Jun 19, 2012
#13
  • Jun 19, 2012
  • #13
My friend got the BBK 78mm and he swears up and down that it made a big improvement on his GT, I guess we will find out at the track though if it helped... I have read that the 78mm is a little overkill for a Mustang with stock heads and cams though.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
J
67 GTA / Shelby tribute mishmash ?
  • Jacksstang
  • Aug 27, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Aug 27, 2026
General karthief
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
