what intake and carb should i use
  • Thread starter Thread starter jake82ga
  • Start date Start date Feb 25, 2008
J
jake82ga
  • Feb 25, 2008
i have built a 306 with kieth black s281 pistons,trick flow heads,ecam,i really cant decided on which one to get thanx to all
superstroke17
79
Greenville, SC
Feb 25, 2008
  • Feb 25, 2008
Personally i always liked the power of the victor jr. intakes. The carb all depends on your intentions. Holley makes a good power but are a pain to get adjusted. Never had luck with edelbrock and always heard good things about the Demon cars. Maybe someone with more knowledge on carbs will chime in. But definately victor jr. intake!! Oh yeah keep in mind that this is a small block and you can have too much carb. I'd keep it below 700 cfm IMO. Good luck!
ttop88
42
indiana
Feb 25, 2008
  • Feb 25, 2008
holley 650dp and a stealth would be my suggestion based on the cam
J
jake82ga
  • Feb 25, 2008
thanks guys but i really do like the victor jr what size came should i go with
J
jake82ga
  • Feb 25, 2008
cam^
Rick 91GT
Mustang Master
95
99
PA
Feb 26, 2008
  • Feb 26, 2008
That really is not enough motor to take advantage of what the Vic Jr will do, the Stealth and a 600-650 is a perfect match, mech secondaries preferred. I also prefer Holley carbs over the E'brocks and the BG Demons...
Is this a street car? Daily Driver?
ttop88
42
indiana
Feb 26, 2008
  • Feb 26, 2008
A TFS 1 would be a good cam if its a DD- street car. It is a much better cam then a "B" cam IMO.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 26, 2008
  • Feb 26, 2008
a 650 cfm would be plenty. i have really enjoied my wiend stealth intake. Just a thought a blow through supercharger/turbo carb are close to the same price as regular carb's. Just a thought if you ever want to go that way down the road. Look into it. I don't know if there are any issues running those carbs on N/A engines. Barry grant makes a nice one.
PUNISHER RACING
1,124
FORD CITY, PA.
Feb 26, 2008
  • Feb 26, 2008
650dp / Stealth or Air Gap gets my vote
T
Tech @ BG
32
#10
  • Feb 28, 2008
  • #10
Thanks, The BT series blow through carbs will not run on a NA motor. They have a lot more circuitry in them and move more fuel due to the needs of the bonnet vs the enclosure. The GC series carbs will run both NA and boosted however if plans are to use the enclosure. Hope this helps.
T
Tech @ BG
32
#11
  • Feb 28, 2008
  • #11
On the 306 we would use the 575 cfm carb. If you duration is under .240@50 you can use the Speed series and if it is over .240 the Mighty series. If plans are to add a supercharger or turbo later then go ahead and get the Mighty series up front to save some money.
Sicarius428
2,085
Feb 28, 2008
#12
  • Feb 28, 2008
  • #12
I would vote for a Holley 600 to 650cfm and a stealth.
Kevin
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 28, 2008
#13
  • Feb 28, 2008
  • #13
Thanks very much. That does help.
84_fox_rod
nebraska
Feb 29, 2008
#14
  • Feb 29, 2008
  • #14
i have an f cam with a perforformer rpm and a 650 speed demon it is a real good setup. i had a holley on it then put the bg on it was night and day difference. my et's improved all most a full sec. just with the beter carb. the holley was a street avenger 650 and it had a really bad dead spot in it that would not go away the bg is the best bang for the buck in my book
M
MaxTheHooker
36
#15
  • Feb 29, 2008
  • #15
i have a 670 holley street avenger on my e-brock performer RPM... ****'s beast.
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
  • Mindseye007
  • Aug 16, 2026
Mindseye007
