  • 1994 - 1995 Specific Tech
what is pinging?
  • Thread starter Thread starter Chin
  • Start date Start date Jun 9, 2005
Chin
39
Naperville
Jun 9, 2005
  • Jun 9, 2005
well i feel like a newbie asking this.. but what exactly is pinging and what are the symptoms?
hah i know a lot about cars so feel pretty stupid asking this..
illwood
636
Worcester, MA
Jun 9, 2005
  • Jun 9, 2005
pinging is pre-ignition
This is a condition where the air-fuel mixture in your engine ignites early and trys to reverse the direction of your engine. I believe the term "ping" comes from the noise that it makes.
Compression ratio, spark advance, fuel quality and quantity all play a role in causing or preventing pre-ignition.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 9, 2005
  • Jun 9, 2005
All of the above looks pretty good to me
Here is another way to think about the ping thing..................
Its an audible indicator telling you.....................
WARNING......LIFT RIGHT FOOT NOW
Later
Grady
94MustangGT5.0
288
Champaign, Illinois
Jun 9, 2005
  • Jun 9, 2005
lol, nicely put.
stang_dan
172
new jersey/north caroline
Jun 9, 2005
  • Jun 9, 2005
but you can also get a pining noise if your running to low of an octane correct im not sure y tho i think because the low octance runs kooler i dont know little help i just knew that running regular on a worked motor cuase it to ping on wot.
dan
stang_dan
172
Jun 9, 2005
  • Jun 9, 2005
sorry for the double post but i went back read it slowly and i get it now i thought u guys where refuring to like preigintion when u shut the car off and it still runs but i was on the right track. the higher compression needs a higher octane otherwise it compustes too soon!!! right
dan
yellowstang1994
338
  • Jun 9, 2005
Yea, it'll basically sound like a can of rocks being shaken up inside your engine, it's kind of hard to imagine but if you ever hear it you will know exactly what it is. A question I always wondered while we're here. What kind of damage can pinging cause? if any?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 9, 2005
  • Jun 9, 2005
Its the tops of your pistons getting beat all to hell
Later
Grady
HISSIN50
34
129
Jun 9, 2005
  • Jun 9, 2005
pinging can be pre-ignition or detonation (they are different).
As the Gradster said, use your own piezos (ears) to monitor and tune accordingly. Higher octane is less volatile, ergo resists detonation [more than lesser octane, all else being equal].
when a car runs after being shut-off (generally carbed cars), that is often called dieseling.
(I toss out different terms should you choose to do an internet search).
Good luck.
pleasehelp
686
Poplar Grove, Il
Jun 10, 2005
#10
  • Jun 10, 2005
  • #10
ok, so what's detonation then? Thanks.
HISSIN50
34
129
Jun 10, 2005
#11
  • Jun 10, 2005
  • #11
Very simply stated, all these terms are related and similar in nature in that they involve a spontaneous explosion of the mixture or part of the mixture.
An internet search will yield tons of information - much more than any of us would want to type out. It is an interesting dynamic in that detonation causes a snow-ball effect.
I am not eloquent enough to accurately describe it all. It is just easier to read a few articles about it, IMHO.
yellowstang1994
338
#12
  • Jun 11, 2005
  • #12
Later
Grady
That sucks pretty bad! My car has been pinging for a little while now. Once in a while and now really bad in hot weather. I need to figure out whats the culprit.
bimmertech
1,123
merriam, ks
Jun 11, 2005
#13
  • Jun 11, 2005
  • #13
pre-ignition is usually a knocking noise and is caused by, well pre-ignition. the pinging noise you are reffering to is caused by detonation which is caused during flame propegation of the ignition cycle. the noise is created by two or more uncontroled flame fronts colliding and moving the piston side to side in the bore.
J
JRPony
83
Las Vegas, NV
Jun 11, 2005
#14
  • Jun 11, 2005
  • #14
Well, I will attempt to explain the difference. The primary difference between pre-ignition and detonation is when they occur. Pre-ignition occurs prior to the regular spark and is generally caused by a red hot piece of carbon or metal in the combustion chamber. This is very commonly caused by red hot edges of the exhaust valve.
Detonation occurs after regular ignition has taken place and is generally caused by over advanced timing, too low of octane or excessive combustion heat. The piston compresses the intake charge, raising cylinder pressure. The spark plug is lit and combustion begins. The cylinder pressures rises even more and at this point the unburnt portion of the fuel charge will be unable to handle the pressure and a second flame front is ignited. This flame front is much faster and more violent then the regular flame and this is what causes the damage.
18mustangs
533
Virginia Beach, VA
Jun 11, 2005
#15
  • Jun 11, 2005
  • #15
In addition to what Grady said, it can damage your piston rings causing excessive oil consumption.
Tim
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Hi from Western Washington
  • Bannister
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 31, 2026
keel
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
J
Intake replace help
  • jshyuw7
  • Jun 19, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 19, 2025
