What is this????
  • Thread starter Thread starter 93stangTN
  • Start date Start date May 22, 2005
9
93stangTN
77
  • May 22, 2005
i'am a newbie with this car, but i was cleanin the motor, and ther is a tank on the left side of the radiatior at the bottom, what is that??? it has 2 lids on it, with 2 hoses running to the bottom side of it?
fox racer
577
Staten Island, NYC
May 22, 2005
  • May 22, 2005
carbon canister.. it vents you gas tank
9
93stangTN
77
  • May 22, 2005
so is there gas in it, or nothing??
Paul Perreca
1,085
  • May 22, 2005
i think its dry carbon, and i also think its for emissions
Paul Perreca
fox racer
577
Staten Island, NYC
May 22, 2005
  • May 22, 2005
no gas in it... but when you store gas (I.IE gas tank) and move it around pressure builds up (like a coke bottle but not exactly). it can eventually become dangerous, especially with a pump that could heat up some, so the fumes are vented through that thing. you can ditch it, but your car will reak or gasoline and its not the safest idea either.
HISSIN50
34
129
May 22, 2005
  • May 22, 2005
if you are talking about the tank on the passenger side, yep, Paul is right on. it contains vapors and uses a solenoid to inject the vapors back into the intake (purge).
2000rangerjoe
  • May 22, 2005
right on guys... some say helps gas mileage too. I would say it helps gas mileage in my expriences with the carbon can.
1Bdazzstang
Orlando
May 24, 2005
  • May 24, 2005
I just did h/c/i swap on my car. When we did it we took the motor out and put a new oil pump in and ****. So while it was out i took the carbon canister off. Im sure it has nothing to do with it, but it seems like my car is getting better gas mileage than it was before. So im not sure if it helps mileage or not, I think it just for emissions. Just my opinion.
HISSIN50
34
129
May 24, 2005
  • May 24, 2005
in the old days fuel vapors were vented into the atmosphere. That is no longer cool, so the relatively complex EVAP system keeps those fumes from being vented into the air (closes the system).
There should be no tangible fuel economy benefit that I can see, but who knows.
good luck.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
