what kind of H.P. will i have and track time
hernandez
44
just built a 347 stroker w/ professional product intake, 70mm tbody & spacer, 75mm MAF, track heat heads, 9.5 compression, n-41 cam, 1.6 roller rockers, CAI, LT headers, custom x, slp loud mouth mufflers, UD pullies, E-fan, 3.73, UL control arms, MT ET street, 30lb fuel injectors, t56, short throw, test drive in one day. thanx:flag:
small steps first hero! 11s are good for now, and in a year or two then 10s, like i said is the N41 too small for my setup? do you guys think that a tfs stage 2 cam will work better
Hands down keep the N41 over the junk tfs 2. If you want to switch cam's, look into a bigger AFM cam or a custom. If you want the most out of the combo, you will need to step up the gear and manifold.
just bought a holley system max II intake for :D 245.00 :D upper from turbomustang.com for 200 shipped and lower from corral.net for 45 shipped. sold the typhoon intake now looking for a cam thinking of stage 2 from tfs or one from comp cams
You sure that lower is a systemax II and not a systemax I? A systemax I is a stock replacement lower for a stock upper. If its a II, thats a killer manifold for your combo. It'd run real hard with an AFM N91 hi rev cam and 4.30 gears :D
