What makes the engine HO?
  • Thread starter Thread starter 3024bblHO
  • Start date Start date Aug 10, 2006
3024bblHO
28
  • Aug 10, 2006
I was curious, take my 85 GT for example. What makes the engine High output (HO)? What parts? Thanks
865.0HO
65
Goldendale, WA
Aug 10, 2006
  • Aug 10, 2006
Roller cam, Forged pistons. Double roller timing chain set.
90_Red_LX
668
Asheboro, NC
Aug 10, 2006
  • Aug 10, 2006
The firing order is the difference. It's suppossed to make more power and run better. The camshaft is what determines whether it's an HO firing order or not. Then it's a matter of getting your wires right. There may be more but thats all I know.
LtDavis
20+ Year Stangneter
Nov 19, 2004
75
Raleigh, NC
Aug 10, 2006
  • Aug 10, 2006
I think its the cam and heads. The heads in your '85 are E5s (I think) as opposed to the E7s found in 87-93s but compared to other cars with 5.0s in them of the time (crown vics and such) I believe the Mustang's stock cam is more aggressive and the only other vehicles the heads are found on is trucks. I might be wrong though so somebody else chime in.
R
R2D2
Aug 10, 2006
  • Aug 10, 2006
cam
superhuaman
907
Harrisburg, PA
Aug 10, 2006
  • Aug 10, 2006
as far as 87-93 goes, HO is determined by camshaft and computer, which determine the firing order, and possibly wiring harness. forged pistons, roller cam, and all that are just nice enhancements only done to the HO, but they dont MAKE the engine an HO
bynummustang
Seen my other Jackstand?
Jul 24, 2005
NC State University
Aug 10, 2006
  • Aug 10, 2006
Ummm... what they said.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Aug 10, 2006
  • Aug 10, 2006
you know that the newest chevy 350's finally are using the same firing order ford uses with the 302 H.O.'s. if you were to number chevy cylinders the same way ford does the new vette engines would have the same firing order. it is the most efficient firing order makes most power due to the cooling time inbetween side by side cylinder firing. if that makes any sense. wtg ford and finally chevy.
carbed87
215
  • Aug 10, 2006
by the way it's the same as a 351 firing order if i recall. oh, and the vtak on the ho's is a little bigger (lol j/k)
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Aug 10, 2006
#10
  • Aug 10, 2006
  • #10
yep same as 351w i think the 351c .
Ford V8
351C (Clevland) 351M (Michigan of Modified)
Firing Order
13726548
G
GREYFOX4INCH
190
western MA
Aug 11, 2006
#11
  • Aug 11, 2006
  • #11
just to throw this out there:
My coupe has an (aftermarket) 302 non-HO cam and it makes more power then a stock 5.0 HO with a 351 fireing order. i never understood the logic behind this (car came with it) but for some reason this is still a perfomance cam, working with factory EEC...
superhuaman
907
Harrisburg, PA
Aug 11, 2006
#12
  • Aug 11, 2006
  • #12
huh, weird
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
C
Progress Thread Whats needed on a 3.8 for a super charger to work reliably?
  • Cryfire
  • Nov 4, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
gkomo
C
Flat tappet to roller lifters--older block
  • chazmanaz
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
Drivetrain Decode this Tremec tag?
  • Scott_S
  • Jul 25, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
