If it never ran correctly then they weren't the best IMO.
Well there's that also. The Pimpxs is more suited for earlier models. I ran into issues that Stinger hadn't even encountered while using it on a '94. One update caused my engine to run in batch fire. Stinger had to post a notice in their forum to warn users.
Getting the A/C to work was unchartered waters. I was on my own while figuring that one out. It goes on and on.
Hot starts were a disaster and were never resolved.
Another issue that I hadn't considered was that the Pimp relies on the old, factory wiring. By the time that I re-pinned the ECU and moved it in and out of the kick panel many times, the factory wiring and connections were really put to the test. The 60 pin connector had broken clips from removing pins and relocating them. I had to install a new 60 pin plug.
I pulled everything out and sold it. My buddy builds classic hotrods for money is no object clientele. One day I watched him install a Holley Sniper 2 on a 632 GM big block in a '69 Nova. I thought there was no way that this setup would work with the nasty cam in that engine. He gets the unit all installed and enters a few parameters in the Holley Wizard. He turns the key and wallah. It fires right up and settles into a nice idle. He checks the timing and looks for leaks. Oil pressure is great. Hop in, let's go for a drive. Before I knew it he was doing a WOT pull. Holy chit! It just kept running better and better the more we cruised. I was sold.
I pulled all of the factory EFI equipment off of my engine including the engine and A/C harnesses. No more CCRM, TFI, etc...
I took my time and wired the Sniper 2 neatly and correctly. I installed a Super Vic carb intake and mounted the Sniper on top. I answered the questions in the Holley Wizard and turned the key. Bam! I couldn't believe how fast it started and settled into a nice idle. After putting some miles on the car, I started playing with the tune. I suck at tuning and am not the best with computers. The Holley software is easier to negotiate and more intuitive.
I tinkered a bit and then sought out a professional to get it all dialed in. The network of tuners and support for Holley EFI in general is huge. Even at the track! With the Megasquirt, I was on my own. There was nobody in state that messed with it.
It gets better!!! A gentleman developed an AI assisted Sniper 2 datalog analyzer that spits out detailed tuning suggestions to squeak every last bit out of the tune. It plain works and folks who are well versed in tuning their Holley's are seeing improvements after using the analyzer and making changes.
Call me a happy camper.
