  • SN95 4.6L Mustang Tech
What modification to launch my automatic?
  • Thread starter Thread starter 01mgvert
  • Start date Start date Apr 27, 2004
First Prev 2 of 2
DaDDyGSp0T
247
Southern Cali
Apr 28, 2004
#21
  • Apr 28, 2004
  • #21
outlaww77 said:
Call Hemlock Transmission 1-561-793-0993 $300 yes $600 nononon
300 for that converter !!!????
Defleshed
Satanic Mechanic
Nov 30, 2003
10,569
In Torment, In Hell
Apr 28, 2004
#22
  • Apr 28, 2004
  • #22
how accurate are G-techs anyway?? I dunno if i'd fully trust it.
san~man
O-G
A little grass shack on a big lava rock
Apr 28, 2004
#23
  • Apr 28, 2004
  • #23
The old saying "you get what you pay for" usually applies.
Never heard of them before.
JMHO, stick with a name brand...PI is one of the best, if not the best. I have one and zero problems after over a year.
9
98SteedaStang
382
Chicago Suburbs
Apr 28, 2004
#24
  • Apr 28, 2004
  • #24
Dark Knight GT said:
The Jerry mod shift kit is the best mod for the money. You use your stock valve body, enlarge the holes in the seperator plate, and modify the accumulator pistons. Its the best and most of all, its safe for your transmission since it was designed by Jerry Wroblewski, an ex-Ford engineer who actually desinged the 4r70w transmission itself. The rest of the transmission will support it. Its not too difficult to install, however, you can mess up your seperator plate. I let a pro do mine....the second time. First time, I drilled the holes wrong cause I used a hand drill. I let this guy do it and he used a drill press. He also got it right cause he's done valve body work for years. He's actually a good friend of Jerry's. Anyhow, the Jerry mod is the best **** kit out IMHO. If you have any questions, feel free to ask.
Can you tell me more about this Jerry mod? Is there an article on it? What does it do and how do you do it? Thanks
BonezGT
20
#25
  • Apr 28, 2004
  • #25
^^^ Yes I'm interested in this also.
00VERT GT
376
SW Florida
Apr 28, 2004
#26
  • Apr 28, 2004
  • #26
not trying to hijack thread or anything and sorry for sounding like a noob but what exactly does a higher "stall" torque converter do?
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Apr 28, 2004
#27
  • Apr 28, 2004
  • #27
01mgvert said:
I see that you have the Precision Industries Stallion torque converter. From my research, this is one of the best. They claim to drop your 60 ft time by .2 seconds and your 1/4 mile time by .5 seconds. Did you find this to be true? Also, is it worth the cost ($695 plus installation)?
As for track times, I dont know yet. I havent had a chance to get at the track, though I will soon enough. What I can tell you is before the torque converter, I could floor it at idle and not even chirp my tires. They just hooked and went. After the torque converter, if I floored it form a standing stop, I'de spin all the way to the rev-limiter, shift into second, and still spinning.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Apr 28, 2004
#28
  • Apr 28, 2004
  • #28
Go to www.tccoa.com and read their articles on the 4r70w automatic transmission. The Jerry mod shift kit is explained in there.
BonezGT
20
#29
  • Apr 28, 2004
  • #29
Thank you sir!
T
TARZAN
446
Philly MS
Apr 28, 2004
#30
  • Apr 28, 2004
  • #30
Get a stall, and some DR's
-Will
decoy562
1,526
Acworth, GA
Apr 28, 2004
#31
  • Apr 28, 2004
  • #31
-Will
Is that what you're doing Will?
-Chris
01mgvert
302
#32
  • Apr 28, 2004
  • #32
I might need to add a torque converter to my future mods list. It would then probably be a good idea to beef-up the rear end: Moser 31 spline axle ($300), Eaton 31 spline differential ($400), and B & M transmission cooler ($50). With the torque converter, we're over $1400 plus installation. Again, is the gain really worth the cost?
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Apr 28, 2004
#33
  • Apr 28, 2004
  • #33
You dont neccesarly need an Eaton 31 spline differential. A factory OEM 31 spline Ford differential for half the price would do just fine. If you had a five speed, then yeah, Ide tell you to go for the Eaton unit.
Go to www.stangstore.com and order the 31 spline trac-lok. Thats what Im putting in mine. Its only 180 some dollars.
BTW, a torque converter is definately worth the money. Beefing up the rear end isn't neccessarly needed unless if you intend to run either slicks and/or see a fair amount of track time. However, its definately a good idea to beef up the rear end to be on the safe side.
Jackie Chan
I didn't read this.
2,507
Orlando, FL
Apr 28, 2004
#34
  • Apr 28, 2004
  • #34
ive never seen a guy break the rear with an auto using i higher stall on stickies....not to say it hasnt happened a lot, i just have yet to hear about it or read a guy posting it.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Apr 28, 2004
#35
  • Apr 28, 2004
  • #35
Exactly. Thats why I think he should save himself some money and go with the OEM Ford 31 spline track-lok instead of spending 400+ for the Eaton unit.
First Prev 2 of 2
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
L
2004 Mustang GT issues after bolt-ons added
  • Leo090
  • Nov 1, 2024
SN95 4.6L Mustang Tech Jan 24, 2025
Leo090
L
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 4, 2026
JD1964
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
