What octane to run on 4.6 GT Anyway?
sickstickGT03 said:
I run 87 on the street, but would it benefit going to a higher octane when I go to the track?
you'll get less power more than likely. the most power you'll get is by running the lowest octane possible without detonation
A while back motor trend did a study on octane, used several cars, honda, saab, MUSTANG GT... with each car used the recomended fuel (mustang 87). Did dyno test for hp and tq, and a gas milage test. The mustang made less power and got less miles per gallon with 89 and 92 than with 87 (not by much but stll worse). I would not use higher octane gas unless SC or Turbo or other major type of performance mod.
Hope this helps. (remember your cars computer was designed to run with 87)
Using anything higher than 87 with stock timing is a waste of money ... you don't need it. Higher octanes burn slower so you may actually hurt performance using it in a car that doesn't require it. My car ran great on 87 before I got my timing adjuster, but now I have to run super.
I need to add to this. Even stock if you live somewhere that gets hot in the Summer and the EPA forces reformulated gas (RFG) on you then you need 91 or you'll knock and ping.
My GT will ping on 87 any time of year unless I drive like a little old lady not from Pasadena.
I can get away with 89 in the cool weather.
I have stock timing, but after I installed my KN FIPK, I noticed a knock, so for now I use the high octane and it takes the knock away. I do plan on getting the timing adjusted once I get it out of storage though.
