  • SN95 4.6L Mustang Tech
What octane to run on 4.6 GT Anyway?
  • Thread starter Thread starter jas142
  • Start date Start date Feb 29, 2004
  • 3
  • 4
First Prev 4 of 4
Bruno Rodrigues
Canada
Aug 7, 2018
#61
  • Aug 7, 2018
  • #61
Like I’ll have to put 94 octane in it if I apply the race tune, it’s just the 9:1 compression stays the same regardless of tune and usually higher octane fuels are only used on higher compression vehicles such as the Mach 1 which have a 10.5:1 compression I think
Mustang5L5
Mod Dude
Feb 18, 2001
43,324
18,049
224
Massachusetts
Aug 7, 2018
#62
  • Aug 7, 2018
  • #62
If you are installing a 93 octane race tune, then the factory ECU map for 87 octane goes out the window. You are no longer stock.
Three major reasons to increase from 87 to 93 octane typically are forced induction (super charger, turbo, Nitrous), increase in compression, and a change in engine tune altering fuel/timing curves. You are doing the latter. More aggressive timing curves will require higher octane to prevent detonation.
Mustang5L5
Mod Dude
Feb 18, 2001
43,324
18,049
224
Massachusetts
Aug 7, 2018
#63
  • Aug 7, 2018
  • #63
Not always the case. The new 5.0 Coyote Mustang has 11:1 compression and it can run on 87 octane. It does so by changing the timing curves. It won't make as much power, but it will prevent detonation. But if you put 93 octane in, it will run more aggressive tune and make more power. This is how the ECU was tuned. and it has various sensors to help adjust.
So compression is not the only criteria when determining octane level. It also depends on engine tune..which you are changing by installing a performance tune. You'll need to run 93+
Bruno Rodrigues
Canada
Aug 7, 2018
#64
  • Aug 7, 2018
  • #64
Ok sweet sounds good, thx man. If I do change back to 87 from 93 for daily driving, fill it up with 87 first, use it up, fill up again and change the tune? Cause I only really use the race tune when I go to the track and gas is pretty expensive as it is lol
Bruno Rodrigues
Canada
Aug 7, 2018
#65
  • Aug 7, 2018
  • #65
Ok that’s cool thx man
Mustang5L5
Mod Dude
Feb 18, 2001
43,324
18,049
224
Massachusetts
Aug 7, 2018
#66
  • Aug 7, 2018
  • #66
If you go back to 87 octane, you can just immediately switch. The danger is less with the higher octane 93 gas in the tank running an 87 octane tune.
It's just when you want to go to the 93 octane tune you really want to make sure you run that tank down as low as possible before topping it off with 93 octane to make sure you got it all out or really dilute what little 87 octane is left into the rest of your tank of gas.
  • 3
  • 4
First Prev 4 of 4
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
W
I have some 4.6 questions.
  • whiskerz
  • Nov 14, 2025
SN95 4.6L Mustang Tech Nov 25, 2025
squeak93
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
