what oil??
  • Thread starter Thread starter 02TruBlueGt
  • Start date Start date Nov 9, 2006
02TruBlueGt
  • Nov 9, 2006
i searched but for some reason couldnt find it. PLease dont kill me maybe im bad at searching but what oil should i run and do you guys think is best to run in a bolt on 02 gt??
san~man
O-G
A little grass shack on a big lava rock
Nov 9, 2006
  • Nov 9, 2006
Ford recommends 5-20 for 01's and up, but a lot use 5-30 since it's more readily available (Wally World sells a Mobil One full synthetic 5qt jug for 23 bux or so).
The common consensus is that Ford switched from 5-30 to 5-20 for CAFE.
Crzyhrse
Seattle, WA
Nov 9, 2006
  • Nov 9, 2006
I think the newer '99-'04's take 6 quarts don't they? My Mach does. I use Mobil 1 5W-20 Synthetic. Some will argue conventional is just as good. Maybe so or not. If I'm throwing money away, that's fine, it's my money.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 9, 2006
  • Nov 9, 2006
Motorcraft 5W-20 synthetic blend with Motorcraft FL-820S filter.
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Nov 9, 2006
  • Nov 9, 2006
mobil 1 and motorcraft filter
Stangdriver13
44
  • Nov 9, 2006
Royal Purple w/motorcraft oil filter, i only use 5 quarts and is 3/4 the way up on the dip stick markings. I think 5.5 is actually what they call for but this is off the top of my head.
D
Dragstr05
643
Stafford VA
Nov 9, 2006
  • Nov 9, 2006
I've been using the same Motorcraft 5w20 synthetic blend with Motorcraft FL-820S filter. I get the filter and oil from my dealer for approx $11 per oil change. Is full synthetic better? Possibly, but I wouldnt go 5,000+ miles to get the real benefit of a full synthetic.
san~man
O-G
Nov 9, 2006
  • Nov 9, 2006
My 01' owners manual says 5 quarts. I think the 02's and up said 6.
Same engine, go figure.
CobraRed_96_GT
1,421
UCSD/La Jolla
Nov 9, 2006
  • Nov 9, 2006
I use Kendall full synthetic 10W-30 which is viscosity SUS @ 100f - 350, 210f - 62.3 and a flash point of 462 which is perfect for a medium to high reving modular medium displacment V8 engine, it's $23.56 a gallon; but i work for the company that sells it so i get a discount. My 96 GT uses 6 qrts.
four six
506
Hobart, IN
Nov 9, 2006
#10
  • Nov 9, 2006
  • #10
its def 5.5 to 6 quarts of oil I got a 98 GT and it takes that much.
Evenflow
yellow snow cone lover
Nov 4, 2004
116
Mass
Nov 9, 2006
#11
  • Nov 9, 2006
  • #11
Pennzoil Fully Syntheic 5w-20 ($18 for 6 qts) and a MotorCraft FL820-S
CobraRed_96_GT
1,421
UCSD/La Jolla
Nov 9, 2006
#12
  • Nov 9, 2006
  • #12
mine takes a full 6 qrts. and thats what is says in the man. and 6 isn't quite enough either cuz its a little over the line, mine's like 6 and 1/4 qrts
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 9, 2006
#13
  • Nov 9, 2006
  • #13
Mobil 1 5w30 and either a Purolator filter or a Motorcraft filter. i have a stash of about 30 motorcrafts at my house, but sometimes i forget to pick one up when i go to change the oil at work.
sgarlic
3,085
Nov 13, 2006
#14
  • Nov 13, 2006
  • #14
Any oil as long as you change it at recommended interval.
IMHO, there's no justification in buying a filter other than the FL-820S.
Tally_4.6
195
Orlando
Nov 13, 2006
#15
  • Nov 13, 2006
  • #15
6 qts. of Castrol GTX 10W-30 and a motorcraft FL820-s.
Kraw
Nail On The Head El Moderatoro
ATL via MSY via MLU via Pitkin, La
Nov 14, 2006
#16
  • Nov 14, 2006
  • #16
ditto
I just take it to the dealer. I try to get 5-8k miles on it between changes
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
