what pistons do I nered????
TNstanggurl
153
TN
what pistons do I need????
OK here the deal, I have a 97 gt with pi swap and WAS using comp 270s until we found out it was having ptv. Now I need new pistons. I called comp but they couldn't tell me much as far as what pistons to get. So I wanted to ask on here, does anyone know what pistons I need? How much of a dish and anything else I need to know. I would appriciate any help. Thanx
Might not help much, but I read a post on another forum where it was mentioned that Diamond makes a good piston that comes with valve reliefs. I am pretty sure that was on a flat top design...no dish, which is what you would be looking for I guess since you are N/A. Hope that gives you a lead to pursue.
TNstanggurl said:
Do the 99 up motors with comp 270s have ptv problems to?
I think the issue is primarily on the 99 and up cars because of the .550 lift combined with the 5* of advance ground into the cam by CC and the amount of duration in the cam. I have read where one guy had issues with the 268AH cam as well on a 99. I would seriously doubt that the NPI heads have a PTV issue with the Comp Cams since they run only .500 lift.
ttt
You know what,i still have no idea.I have just seen soo many people do it.I know that it bumps your thread back up to the top again so everyone will notice it,but ihave no idea what it means :shrug:
