What ring & pinion is this?
ChickenJoe
McAlester,OK
I just purchased an 86 GT. I pulled the diffy cover off to slide the axles out , so that I could install 3" studs. Figured I would ck the gear ratio while I was in there. The ring gear had 41 15 & 423 stamped on it. WTH??? I did some internet research & found nothing. Any ideas??
When ALL ELSE FAILS.... Count the teeth on each gear. Number of ring gear teeth divided by number of pinion teeth= ratio.
