  • 1994 - 1995 Specific Tech
What RVT?
  • Thread starter Thread starter 95mustang_gt
  • Start date Start date Jan 7, 2006
9
95mustang_gt
364
Wisconsin
Jan 7, 2006
  • Jan 7, 2006
What RTV?
Does it matter on the color on RTV i use for my intake gasket?I got some Permatex Ultra black hi-temp RTV silicone gasket maker(PX #82180).Should that work fine?
thanks
Jesse
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Jan 7, 2006
  • Jan 7, 2006
Just be sure the RTV sealant you use is the hi-temp stuff and you should be fine.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jan 7, 2006
  • Jan 7, 2006
black should be fine for the intake, thats what i used
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jan 7, 2006
  • Jan 7, 2006
Color does not matter, as long as its ultra rtv you're fine.
CManT1914
3,172
Killeen, Texas
Jan 7, 2006
  • Jan 7, 2006
I think I used red. But mine leaks.
9
95mustang_gt
364
Wisconsin
Jan 8, 2006
  • Jan 8, 2006
ok ,thanks for the help.
One more question, to take the old gasket material off the heads i know i need a razor but what else can make the process easier?
mootang
907
texas
Jan 8, 2006
  • Jan 8, 2006
if they are iron heads you could use a wire brush but then you will have debrie everywhere which probably wouldn't be to good.
CManT1914
3,172
Killeen, Texas
Jan 8, 2006
  • Jan 8, 2006
Even if he scrapes it off, there's gonna be debris in the cylinders and other places. Use a wire brush and vacuum up all the pieces. Make sure to vacuum out the cylinders real well too.
Zero Signal
2,633
Tucson, AZ
Jan 8, 2006
  • Jan 8, 2006
I use ultra copper on everything. But I changed the water pump in my Bronco with regular blue and never had a leak. Just remember to be patient with that stuff. What I found to work really well is to torque your bolts at 20-30 in-lbs or so, wait a day then torque it all the way down. That way it doesn't just all ooze out before it cures! I still have no clue what the difference is between Black, Grey, Blue, Red, Copper RTV I was actually going to post that question.
94MustangGT5.0
288
Champaign, Illinois
Jan 9, 2006
#10
  • Jan 9, 2006
  • #10
I used a wire brush to remove the gasket material from my heads when I did the intake swap. I put rags in each port of the head before using the brush, then just pulled the rags out with any debris laying on top of the rags. Then like Chris said, you can use a vacuum and suck the debris out of the lifter valley. Just make sure you don't use something that you won't be able to get back out of the port, I've seen a picture of someone who had paper towel plugged in their valves, it wasn't pretty. Good luck.
illwood
636
Worcester, MA
Jan 9, 2006
#11
  • Jan 9, 2006
  • #11
If you go to the Permatex website, they have a PDF catalog of all of their automotive products that has an application chart inside.
Basically it's a heat range vs. ductility thing. The copper is supposed to be good for everthing except intake end seals (not ductile enough would be my guess). Black is good for most things except thermostat housings, water pump cover gaskets, and exhaust manifolds. Blue is almost the same as the black, but not reccommended for intake end seals.
The Grey is for everything import except exhaust manifolds. . .
urban96
3,464
Syracuse, NY
Jan 9, 2006
#12
  • Jan 9, 2006
  • #12
damn... i used the black (very lightly) because i didnt want to drive to the parts store to pick up another t-stat housing gasket...
its been trouble free now for almost a year if i have any problems ill buy a $2 gasket
9
95mustang_gt
364
Wisconsin
Jan 9, 2006
#13
  • Jan 9, 2006
  • #13
So,when i swap my intake i am only going to use RTV on the lower gaskets and the t-stat housing gasket?I dont use any on the upper intake,and the throttle body gaskets.Just asking to make sure.This is my first time dealing with gaskets.
thanks
Jesse
v6v8swap
113
Oklahoma
Jan 9, 2006
#14
  • Jan 9, 2006
  • #14
95mustang_gt said:
So,when i swap my intake i am only going to use rvt on the lower gaskets and the t-stat housing gasket?I dont use any on the upper intake,and the throttle body gaskets.Just asking to make sure.This is my first time dealing with gaskets.
thanks
Jesse
Sounds right to me. Good Luck!!
Phil
94MustangGT5.0
288
Champaign, Illinois
Jan 9, 2006
#15
  • Jan 9, 2006
  • #15
thanks
Jesse
First off, I'm not trying to be a prude but its "RTV", not "RVT". Just wanted to save you from some embarassment or confusion down the road. Second, I put a dab of the black high-temp RTV in the corners of the lower intake gasket and a bead of it on the front and back of the lifter valley. Don't use the cork gaskets that some kits include, just use a nice bead of RTV from one gasket to the other across the valley.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
should there be an separate gasket on intake manifold ('98 GT) (use permeatex?)
  • dochawk
  • Sep 28, 2024
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2024
Chuckster101
C
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
