what should i do?
treyh
hey im building my first mustang. so far i got a 302 block out if a 93 cobra, stock crank, stock connecting rods, and a f303 cam. planing on puting it in a fox body. so i was thinking about the gt40 heads ported and the street heat intake ported to match. im gonna bore the block over .030. would that be a decent set up and what kind of numbers could i expect. 300??
thanks
Go with the GT-40P's. They flow more out of the box. If you add some porting, you're that much ahead. If you're going with a street motor, shoot for high 9's to 10.5:1 compression. A boost in compression will net some good power. if you're planning on a blower later though, leave it around 8.5:1.
heads
i would put the trick flow heads on it. stay with the cam u have put some bigger headers on it. on the intake i would get 1 to go with the heads 24 pound inj, 70mm tb, bigger mass air, with that if u can drive i think low 12 high 11 on motor
