  • 1994 - 1995 Specific Tech
What Size Push Rods
  • Thread starter Thread starter sgarrelts01
  • Start date Start date Sep 25, 2009
sgarrelts01
133
Niles, Michigan
Sep 25, 2009
  • Sep 25, 2009
Figured out the problem i was having was my cam.
Put a flat tappet cam in now i have to convert it over to roller.
if i use this cam
COMP Cams CL35-328-8 - COMP Cams Xtreme Energy Cam and Lifter Kits - Overview - SummitRacing.com
and some 1.7 rockers
What size push rods will i need.
Adam95GT
2,564
Burlington, NJ
Sep 25, 2009
  • Sep 25, 2009
you will need to check for your self... noone can tell you what length you will need every engine is a little different
sgarrelts01
133
Niles, Michigan
Sep 26, 2009
  • Sep 26, 2009
the reason it was my cam was because it changed my firing order an caused the computer to still use the stock order.
The entire block is flat tappet an not roller, i was going to convert it back to get a roller cam with the right timing order.
But i just found this cam
Comp Cams 35-330-3 Comp Cams 'Magnum' Hydraulic Flat Tappet Camshafts
its a flat tappet and its the correct timing i need
D
Early ford 302 heads
  • Dagasser
  • May 4, 2026
  • The Welcome Wagon
The Welcome Wagon May 4, 2026
T
408w pushrods
  • Towegage
  • Sep 19, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 19, 2025
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
SN95 New Heads
  • Blakeknight
  • May 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
