what size throttle body to get??????
RageStang
14
i want to make sure i get it right. please help me. i got a supercharger that runs 8psi. i got bigger injectors to suport the fuel with the Fuel manegment system. i got a stock 60mm tb in there right now...plz help
Ive never had a problem with my Digital 6 box. If mine ever takes a dump on me i have the adapter harness where i can just hook the stock coil back up and run the factory ignition.
If MSD was really as bad as the internet made them out ot be i bet the digital 7 boxes would not be in 95% of every small tire car that is at the dragstrip
True, while I have had a MSD here and there it happens with all components, you hear about the MSD since 95% of guys out use them....the failure rate will be higher, and the internet spreads bad info like a CA wildfire.
I like the idea of Intake, TB and MAF, although Id personally do a Pro-M meter with the boosted combo. Id use the Track Heat over the Street Heat to give you more room tog row in the future.
I have a Digital 7+ (7531), I had a 6AL, and in the old school days I had a 6A. None of them have ever caused a problem for me. My brother still might be running my old 6AL. He might have mentioned it finally had a problem. I'll ask.
We had an MSD "ready to run" (no box) distributor fail in one of our '69s. It didn't quit running completely, but ran really badly driving the 200 miles home from Roundup in Bellevue last month. We put a stock points distributor back in, and all is well.
