What spark plugs are you happy with?
On all the differen't forums I frequent, HT0's or HT1's and Brisk plugs are the most popular by far. A lot of the nitrous guys like the Brisk plugs and it seems the blower guys have better luck with HT0's.... The HT1's are actually identitical to what comes in our cars from the factory.
Plus, Brisks' are slightly cheaper until you get into the zero and negative heat ranges. Thats probably one of the reason's nitrous guys love them... :D
Also, the electrodes and straps are made out of the same material.
Really? How do you figure? Not trying to disprove anything; I just want to know.
Interesting....good to know, and thanks! Although I don't remember my OEM plugs saying "Ford Racing" on them when I swapped them out. If I remember correctly, they were "Motorcraft" parts. Is there a difference between the two?
I'm not 100% sure on that. I think they have a differen't part numbers, but that could be a function of profit over from. Also, the most recent plugs are slightly differen't and one piece.
Does anyone know why Ford started using this plug design. Was there something wrong with the standard plugs that have been used for nearly a century?
I would think it has something to do with the shape of the heads for the newer OHC engines. I've never owned a 2V OHC Stang, so I don't know what those plugs look like. If they look like these, then I would think it is safe to assume the change of plugs came along with the change to modular engines. :shrug:
Same here never had a 2v mod motor. Anyone know if the 2v mod motors had this style plug or the standard style?
2 valves have the standard plug style. Three valve plug uses this design because of the spark plug placement in between the valve, you just need a real damn long plug.
Dan
