- Sep 4, 2004
- 315
- 0
- 16
i have an 02 gt and i want to lower it no more than 2 inches. what springs or kit has high satisfactory, and is there an advantage to steel vs. aluminum cc plates? thanks
Evenflow said:Whats the max drop you can go before having to replace shocks/struts/etc
Since I have a 04 GT I dont need to replace shocks/struts just yet. a 1.5" drop looks good, but I think a 2" drop looks better but what else would I need to do with the 2" drop? And how does the 2" drop affect driveability/handling?
Blue70 said:I can't say enough about my Steeda Sport Springs.![]()
But I'm sure the H&Rs are just as good![]()
Steve Curry said:I am also looking for lowering springs. I called Steeda about their springs, and they said I needed caster and camber plates, bump steer kit, and ball joints (?) to go with the Sport Springs to get the car to drive correctly. Did you need all of this stuff to install your springs?
StangPro said:Read this:
http://www.stangpro.com/cgi-bin/yabb/YaBB.cgi?board=rant;action=display;num=1115568174
Need? no...
Should you get them? Yes
Blue70 said:That is the same thing I found about CC plates, but it don't mention Bump Steer Kit, or Ball joints![]()
Evenflow said:They just trying to get ya for your money. With Steeda's drop you shouldn't have bump steer probs.
Almost everyone does it theirself.Steve Curry said:OK, I bought the Steeda 3 bolt C/C plates, and the Eibach Pro Kit springs. Hopefully that'll do it for me.
Did you guys install your front springs at home, yourselves? Or did you have it done for you? If you did it yourself, what is the process?
Thanks
