what stall speed for me?
  • Thread starter Thread starter biggyfan1
  • Start date Start date Apr 11, 2008
biggyfan1
186
High Desert CA
Apr 11, 2008
  • Apr 11, 2008
66 mustang, 347, afr heads, long tubes, TCI super street fighter c4, holly 600 cfm, performer rpm intake, etc etc. im sure the most important thing is the cam so here is the spec's on it. gross valve lift intake .536 exhaust .544
duration @ .050 224 230
i dont have gearing but i will gear it with 373 or 410's when the money comes in.
the car is going to be a weekend worrier and see some track. im looking at 2 different converters. one is a stall speed of 2200-2800 the other is 2800-3200, does this seem like something my car is going to like?
jerry S
1,365
52.22N 5.12E
Apr 11, 2008
  • Apr 11, 2008
It sounds like you have an 8.8 inch rear. I have a similar combo in my car. I have a 9 inch rear with 3.70 in the back and a 2800-3000 stall and my car just loves it. I think a similar combo to mine would be more "streetable" than 4.10s and still get you down the track plenty fast.
woodsnake
1,352
15
69
Hicksville, NY
Apr 11, 2008
  • Apr 11, 2008
Who made the cam in your engine? Usually, like with 'comp' cams, there is a 'prefered' list of specs that come with the cam itself.
I.E., cam "A" requires 3.50 or taller rear gears, and a 3000+ stall TQ.
Probably your cam maker can best answer your question. Obviously, since you spent the coin for the stroker, you want the best performance from the total package....
10secgoal
2,801
San Diego
Apr 11, 2008
  • Apr 11, 2008
I'd look in the 3-3500 range depending on how much of a drag car it is. 3 would be more street obviously. But with a bigger motor, may go a little higher than 3. The streetfighter would be a good pick for that. My 302,185's,4.11's and 3500 went 7.6's all day long. Yours ought to move pretty well.
bnickel
5,640
lubbock, texas
Apr 12, 2008
  • Apr 12, 2008
i have a similar cam (duration wise) and i'm running a stock convertor and 3.25 gears, it's about as big a cam as you can get away with a stock convertor. for streetability i'd go with the 2200-2400 stall and the 3.73 rear if it was mine. remember the higher the stall speed the more heat is generated and heat is what kills automatic trannies. if you're less worried about driving and more interested in the best 1/4 mile times then go with the higher stall.
biggyfan1
186
High Desert CA
Apr 12, 2008
  • Apr 12, 2008
thanks for the info guys. im going to get the 2800-3000 one.
D
D.Hearne
11,730
south louisiana
Apr 12, 2008
  • Apr 12, 2008
With the future gearing and cam you'll be happier with the lower stall converter. The converter in my 331 is in the 1500-2500 range and with a Z303 cam (.587 lift, 228* duration) it's just fine with it with 3.50 gearing. Just a light touch to the gas pedal is all that's needed to light em up.
biggyfan1
186
High Desert CA
Apr 12, 2008
  • Apr 12, 2008
im looking on Ebay for a converter and i see the Bosshog ones. they have one that is 2200-2800 and then another one 2800-3200. i love the price. it would be nice to have a TCI brand but not for 400+ bux. so you really think i will like the 2200-2800 stall huh? im new to this AUTO/C4 thing so i dont know what to expect. i want good drivability but i also want to be in the 11sec 1/4 mile times. thats a tuff time to get up here in the high desert. lol
biggyfan1
186
High Desert CA
May 9, 2008
  • May 9, 2008
crap i need to buy one today and im still not freakin sure.
jb1dsl
566
Marianna, Fl.
May 9, 2008
#10
  • May 9, 2008
  • #10
2200-2800 would have better streetability. remember with a stroker your motor will stall up in the highter rpm range versus a stock 289/302.
iskwezm
4,159
20
79
Rowland Heights,California
May 9, 2008
#11
  • May 9, 2008
  • #11
I used to use a 3300 behind my 289.I probably coulda went a little higher, but with a 3300 it had no drivability issues as people say and you couldnt even tell it was that high of a stall.On the bottle it stalled a little higher
I say go for a stall of 3000-3500.
blown65
1,938
Queen Creek Arizona
May 9, 2008
#12
  • May 9, 2008
  • #12
Ditto, I have a 10.5" 3500 in mine and its street drivability is just fine. Mine was custom done though, not a Jegs order converter which IMO helps cause the converter guys can do things to help you out with your particular build.
IMO I would contact someone like ultimateconverter and see what they recommend. In a month or so Ill probably be selling my converter since I need a much much looser converter for my build (around 5500-6000rpm) I could probably make ya a great deal on it.
biggyfan1
186
High Desert CA
May 9, 2008
#13
  • May 9, 2008
  • #13
here is a look at my cam card. This may help you guys further answer me. i didnt have this thing scanned before but here it is now. View attachment 318492
someone was saying comp cams puts a recommendation for a stall speed on the card but they don't. not on mine as you can see.
blown65
1,938
Queen Creek Arizona
May 9, 2008
#14
  • May 9, 2008
  • #14
Call comp cams, they should give you a rough idea
D
D.Hearne
11,730
south louisiana
May 9, 2008
#15
  • May 9, 2008
  • #15
biggyfan1 said:
here is a look at my cam card. This may help you guys further answer me. i didnt have this thing scanned before but here it is now. View attachment 318480
You've got a custom ground cam there. It's not listed in Comp's off the shelf grinds. According to the duration figures, and matched in their converter list you'd want a 2200-2400 stall.
brianj5600
1,964
Middle TN
May 9, 2008
#16
  • May 9, 2008
  • #16
If you want to go 11's, you need at least 3000. It will be a dog with sticky tires and any less.
calpolymustang
217
Santa Rosa, CA
May 9, 2008
#17
  • May 9, 2008
  • #17
where are you located?
two months ago, i bought a 24-spline 3000-3500 10" from BTE Racing in Memphis, but my 289 is having valve issues and im going to drop in a stock 5.0 long block. I may want to go back back to my stock converter, since ive been told the 3500 is a lot for a stock 5.0
i highly recommend BTE Racing, who will ship a custom build converter to your door for $340. check out bteracing.com, and they should still have their 10" special going on. they have very good customer service over the phone
iskwezm
4,159
20
79
May 9, 2008
#18
  • May 9, 2008
  • #18
Vinyl66
398
#19
  • May 9, 2008
  • #19
C
What do you think???
  • Clodracer1000
  • Mar 19, 2018
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2018
Steel1
Torque Convertor stall speed
  • Cobra912
  • Nov 4, 2009
Fox 5.0 Mustang Tech Nov 7, 2009
Dino Dino Bambino
What size stall?
  • 1967project
  • Jan 20, 2009
4K
Classic Mustang Specific Tech Jan 22, 2009
thexrcist68
M
any guess on hp and times on this combo?
  • mustang6075
  • Jan 6, 2010
Fox 5.0 Mustang Tech Jan 6, 2010
SpartaPerformance
A
What cam is best for me?
  • adamford150
  • Nov 4, 2008
Fox 5.0 Mustang Tech Nov 4, 2008
Lunch Box
L
