  • SN95 4.6L Mustang Tech
What superchargers work with 87 octane?
  • Thread starter Thread starter MustangJunkie
  • Start date Start date Dec 25, 2007
M
MustangJunkie
97
Northern VA
Dec 25, 2007
  • Dec 25, 2007
Or do all superchargers require 91+?
Thanks!
fobra559
At least it's more erect and not floppy anymore.
Nov 1, 2007
721
Lindsay, CA
Dec 25, 2007
  • Dec 25, 2007
You MUST use 91 octane fuel or higher in order to avoid detonation and engine damage.
T
tire
37
  • Dec 25, 2007
with low enough boost you 'could' make any forced induction work with 87 octane. however, there are many reasons why doing so would not make sense nor would it be particularly safe.
1) higher octanes prevent detonation. detonation can quickly cause severe/catastrophic engine damage. "blowing your motor"
2) if you are putting money down for a supercharger (3-6k), why would you want to settle with 87 oct when 91-93 is available at the pump and could produce 5-15 more hp?
3) most chips that come with supercharger kits are flashed for 91 oct (as california has 91 as max oct, and keeps the kit 50 state legal).
an anology would be you expanded your home and built another wing, but decided to pass on installing running water and fire alarms. if you are going to make such an investment, spend a tad more to make it safe and so you can get use out of it.
the only situation i would say running 87 oct with a s/c *might* be acceptable, is if you had virtually no funding and someone just gave you a s/c and you want to run 4-5 psi and found a chip or tuner that flashed for 87. even under those circumstances, i wouldn't do it.
austin
M
MustangJunkie
97
Northern VA
Dec 25, 2007
  • Dec 25, 2007
Thanks for the quick answer.
Ok, so what's the best S/C for the money, i.e. biggest bang for the buck or value?
Superhereaux
chicks make me feel inadequate
538
South Texas
Dec 25, 2007
  • Dec 25, 2007
http://modularpowerhouse.com/product_info.php?products_id=121
fobra559
Nov 1, 2007
721
Lindsay, CA
Dec 25, 2007
  • Dec 25, 2007
Vortech, Paxton and Procharger provide great gains for about 3-5k depending what kit you get. You can actually build your own kit for about $1,500. Someone on the forum here has done it before around that cost.
fobra559
Nov 1, 2007
721
Lindsay, CA
Dec 25, 2007
  • Dec 25, 2007
That's a good deal right there.
the98stang
2,408
Clovis, CA
Dec 25, 2007
  • Dec 25, 2007
Used S-trim kit from someone on the boards.
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Dec 25, 2007
  • Dec 25, 2007
if you cant afford 93 octane than you cant afford a s/c lol
fobra559
Nov 1, 2007
721
Lindsay, CA
Dec 25, 2007
#10
  • Dec 25, 2007
  • #10
G
gsjohnson
81
Woodland Hills, CA
Dec 25, 2007
#11
  • Dec 25, 2007
  • #11
The deal is you want all the hp you can get when laying down S/C money, which is considerable. You can run 87 octane with most of them...Just dial the timing way back and richen up the fuel mixture. Of course you just gave up 40 to 50 horsepower. Now you decide...
fobra559
Nov 1, 2007
721
Lindsay, CA
Dec 25, 2007
#12
  • Dec 25, 2007
  • #12
I would not to want to buy a SC to give up 40-50hp to save for 87. If that's the case, I would just get laughing gas
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Dec 25, 2007
#13
  • Dec 25, 2007
  • #13
boost increases compression. even with the timing retarded significantly, you could get detenation just from the compression like a diesel with 87 octane.
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
Fox price for fuel
  • Mindseye007
  • Jul 20, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 27, 2026
AeroCoupe
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
