What swaybars to get?
stang22 said:
Steeda, Maximum Motorsports. MM probably has the best around IMO, but you are going to pay a little bit more.
Why are you upgrading? What else have you upgraded on your suspension to make you want to upgrade the sway bars? From most people, new bushings and end-links will do it.
Rear sway bar from MM:
http://www.maximummotorsports.com/rsb.asp
Steeda has some tubular from sway bars.
Yea, the MM RSB is way too much $.
I want to upgrade because I'd like better handling. See my sig for mods. :nice:
I am assuming that when you put your springs and struts/shocks on, you changed all of your bushings to poly bushings? Have you change your sway bar end-links and sway bar bushings?
How about a torque-arm or a pan-hard bar?
You have already upgraded your struts/shock and springs, wheels/tires and brakes. What else do you want to upgrade for cheap that is going to help you handle better? :p
Tim
