what the heck
  • Thread starter Thread starter wlabrum
  • Start date Start date Jul 8, 2009
W
wlabrum
26
  • Jul 8, 2009
put some low mile rebuilt d8oe heads and timing chain on my 302 now i have oil in the water
how can that be
as far as i know there are no oil passages thru the block to the head
any body got any ideas
thanks
apollo12
155
port st.lucie fla
Jul 9, 2009
  • Jul 9, 2009
what year block do you have?
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jul 9, 2009
  • Jul 9, 2009
im gonna go with valve seals, mabye you bought junk heads. did you have them checked before you bolted them on?
W
wlabrum
26
  • Jul 9, 2009
motor is a 82
valve stem seals wont allow oil into water
is there any oil passages between b-head
or block timing cover???
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jul 9, 2009
  • Jul 9, 2009
If you had bad seals on the head and your head gasket was leaking, you could get oil in the coolant. or its seaping in a gasket somehwere else.
skunk21
1,203
Taxachusetts
Jul 9, 2009
  • Jul 9, 2009
The tough part is this could be coming from a number of sources. anything from a crack in the head or a cracked block. It could come in from the timing chain cover area through a worn/cracked cover, etc. another source could be the lower intake or the head gasket oddly enough. I know you just installed low mileage heads but there could be slight chance they have a hairline crack in them. I would look at the timing cover again since you just did that, also recheck the lower intake.
W
wlabrum
26
  • Jul 9, 2009
carbed motor
took out of pickup to put in 88 drop top
old motor had a bad valve seat so i swapped heads with known good used ones
there is no water in oil
but oil in water
has 5 spd so its not transmisson fluid
going to flush cooling system and pressure test
skunk21
1,203
Taxachusetts
Jul 9, 2009
  • Jul 9, 2009
wlabrum said:
carbed motor
but oil in water
That is a good start but just because the other symptoms listed by us most of the time present with water in the oil doesn't mean it's always the case. A cracked/worn or leaking timing cover can do the same just like a lower intake gasket and a head gasket. don't rule it out just because of how the symptoms present.
W
wlabrum
26
  • Jul 9, 2009
tried to flush cooling system
with rad cap open and hose flowing in
oil contamanated water was flowing out and not showing signs of stoping after 1 hour
pressure checked system and bleeds off a pound a minutish
pressure checker does not rise with rpm
so..........where is the oil coming from????????????????
W
wlabrum
26
#10
  • Jul 9, 2009
  • #10
have not pulled oil drain plug but oil level hasent changed and oil shows no sign of contamanation
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jul 9, 2009
#11
  • Jul 9, 2009
  • #11
this is a question that i dont think anyones gonna have a good answer for, theres alot of reasons that there could be oil in the coolant, and is gonna be a bitch to find it. i would suggest getting a HO motor cheap somewhere rather than chasing your tale with this
W
wlabrum
26
#12
  • Jul 9, 2009
  • #12
follow up...........
flushed coolong system with dish soap followed by laudry detergent
6 cycles
then flushe with clear water.
drove 25 miles no sign of any more oil like substance in cooling system
diagnoise:
wally world anti freeze that i used must of reacted with prevous anti freeze or other prevous cooling system addative
never seen nothing like this before nor probally never see again
BIG THANKS TO ALL THAT TRIED TO HELP
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 4:40 PM
manicmechanic007
