What The Maf??!
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Ok ive been trying to figure this out forever now.. I have a C&L 73mm MAF for #24 injectors. The car seems to run rich but o2s read lean. So new o2's, same issue. New MAF sensor, same issue. The voltage does not peg but it reads 1.1 volts at idle. called C&L they said it should be at .75 or so so i put small layers of tape on the sample tube till i got the voltage down to .75 ish.... car wont run.. remove the tape to bring voltage back up car runs but too lean...
Im starting to wonder if the A9L that came with the car has a tune burned on it already.... Any takers??
The A9L has no flash memory like more modern car computers. Therefore the stock tune cannot be altered without adding additional hardware to the computer's J3 service port. The prom that contains the computer's program is soldered in place and would not be easy to remove and replace with something different.
I don't see how the car is actually running rich, yet the sensors read lean.
If the sensors are good, they will read whatever is there, not what a PCM or MAF wants them to read.
So, IF the sensors are good, and the sensors say it's lean, then it's lean.
If the car is running rich, the sensors would read rich.
Now, how the PCM interprets that info is a different story, but I am just trying to make sense of what you are saying...
"Car is rich, but sensors read lean..."
My bet would be a problem with the MAF, since a good sensor is a good sensor...
My thought would go something like this:
Ditch the C&L meter and get a good meter. One that didn't come jury rigged from the manufacturer with some more jury rigging in the garage. Putting tape on a sample tube (though creative) is probably (just guessing here) not going to be as accurate at adjusting a meter housing on a flow-bench-machine. O_o
You're thinking is that the signals generated by the meter are linear as RPM and airflow increase. They are not. The shape of the housing and element tube are just as important as their size.
Buy a real meter.
It sounds like what's happening now is that the meter you have is a mismatch. It's reporting more air than what's actually going through it. In turn, the EEC is reading AFR lean and trying to dump even MORE fuel into the mix at a power setting that the motor doesn't require.
Try this: http://promracing.com/
The car simply smells like its running rich, i dont think so but my girlfriend wont shut the **** up about it, she smells exhaust but car has no cats. I have a basic A/F gauge in the car its a light show gauge but gives me a ballpark from what it reads the car is lean, very lean.. I simply ran the tube in its modified condition in the garage. When the car would not run i removed tape till i got a .85 ish reading car ran but even leaner. So i removed the tape and it returned to "normal" the car runs well and it does great when im in the throttle, but at idle the car will "lean out" even though the voltage is still 1v. Am i looking for a problem thats not there?? does lean have a smell??? just trying to figure this out i get alot of contradicting info from different sources about what the voltage reference should be... If i cant get this figured out soon im gonna trash this meter whats a good replacement.??
If it matters fuel pressure is 39lbs, sensor is new it is the one for A9L, Injectors areFRPP #24 crome top black bottom( came with car), BBK cai
Thanks for the help
No cats= stink... No way around it..get a real afr gauge..light show gauge is just that, a light show..for 200$ you can get an innovate motorsports unit..what is your current gauge currently connected to? Hopefully not your o2 sensor.
Well that would be correct the line is soldered into the output for the o2 on the driver side... per the manufacturers instruction.. will that cause some kind of issue??
Second issue beating around under the hood the injectors have a common part number on the body 01d126b but on the neck two of the injectors have 3257 and the other six have 3307 i tried crossing the number to no avail... called summit too they say they are not theirs... they came in a FRPP box but that dont mean they are...... any suggestions? They all look the same
Fuel injector sizing & injector photos
Revised 11-Dec-2011 to add larger injector sizes to injector table
Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines at the flywheel.
Example:
19/.5 = 38, 38 x 8 = 304 HP
24/.5 = 48, 48 x 8 = 384 HP
30/.5 = 60, 60 x 8 = 480 HP
36/.5 = 72, 72 x 8 = 576 HP
42/.5 = 84, 84 x 8 = 672 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
19/.5 = 38, 38 x 8 = 304 HP x .85 = 258 HP
24/.5 = 48, 48 x 8 = 384 HP x .85 = 326 HP
30/.5 = 60, 60 x 8 = 480 HP x .85 = 408 HP
36/.5 = 72, 72 x 8 = 576 HP x .85 = 490 HP
42/.5 = 84, 84 x 8 = 672 HP x .85 = 571 HP
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
See http://users.erols.com/srweiss/ to get the calculators used in these examples.
Here's the duty cycle explanation. Duty cycle is how much of the time the intake is open the injectors are turned on. The 85% figure means that for 85% of the time the intake valve is open, the injectors are spraying. The idea is that you want some percentage of the duty cycle left over so that you have some room to grow the process.
If you are at 100% and you need more fuel, all you can do is turn up the fuel pressure. That means the whole fuel curve from idle to WOT is affected. Maybe you are already too rich at idle, and turning up the fuel pressure makes it worse. If you had some injector duty cycle left to play with, a custom tune could use that where it is needed. That would not over richen the whole range from idle to WOT.
If you did turn up the fuel pressure, you might be able to change the injector duty cycle to get the air/fuel mixture ratio you want since the injectors will have extra fuel delivery capability.
With larger than stock injectors or higher that stock fuel pressure, you will need an aftermarket MAF that matches the injector size. The MAF “lies” to the computer to get a fuel delivery schedule that meets the engine’s needs and isn’t too rich or too lean. The best strategy is an aftermarket MAF and a custom tune to insure the best air/fuel ratio over all the RPM range.
Don't forget to increase the fuel pump size when you increase injector size or significantly increase the fuel pressure
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
it won't cause an issue but it's not doing a thing for you.
o2 sensors are narrowband.. You need to have a wideband setup to be more accurate.. That gauge is basically just for show. On a real wideband kit you have another sensor that gets put in the exhaust, and gives you a number not a blinking light. Only two ways I know of to figure out what you have going on. Buy a wideband kit or put it on a dyno with the sniffer they put in your exhaust.
Thanks for all the info guys.. i think i will be investing in a 80mm pro m maf seems like the best bang for the buck and my tuner (if i ever get there) will appeciate it. What fuel pump should i be running with my current setup?
Copied from the FORD RACING PERFORMANCE PARTS catalog:
PROPERLY SIZING FUEL SYSTEM COMPONENTS
Fuel Pumps
The following information is presented assuming the above information has been taken into consideration regarding BSFC, fuel pressure and specific gravity of the fuel being used. Most fuel pumps for electronic fuel injection are rated for flow at 12 volts @ 40 PSI. Most vehicle charging systems operate anywhere from 13.2v to 14.4v. The more voltage you feed a pump, the faster it spins which, obviously, will put out more fuel. Rating a fuel pump at 12 volts then, should offer a fairly conservative fuel flow rating allowing you to safely determine the pump’s ability to supply an adequate amount of fuel for a particular application.
As previously mentioned, engines actually require a certain WEIGHT of fuel, NOT a certain VOLUME of fuel per horsepower. This can offer a bit of confusion since most fuel pumps are rated by volume, and not by weight. To determine the proper fuel pump required, a few mathematical conversions will need to be performed using the following information. There are 3.785 liters in 1 US Gallon. 1 gallon of gasoline (.72 specific gravity @ 65° F) weighs 6.009 LBS.
To be certain that the fuel pump is not run to its very limit, which could potentially be dangerous to the engine, multiply the final output of the fuel pump by 0.9 to determine the capacity of the fuel pump at 90% output. This should offer plenty of ‘cushion’ as to the overall “horsepower capacity” of the fuel pump.
To determine the overall capacity of a fuel pump rated in liters, use the additional following conversions:
(Liters per Hour) / 3.785 = Gallons
Multiply by 6.009 = LBS/HR
Multiply by 0.9 = Capacity at 90%
Divide by BSFC = Horsepower Capacity
So for a 110 LPH fuel pump:
110 / 3.785 = 29.06 Gallons
29.06 x 6.009 = 174.62 LBS/HR
174.62 x 0.9 = 157 LBS/HR @ 90% Capacity
157 / 0.5 = 314 HP safe naturally aspirated “Horsepower Capacity”
Safe “Horsepower Capacity” @ 40 PSI with 12 Volts
60 Liter Pump = 95 LB/HR X .9 = 86 LB/HR, Safe for 170 naturally aspirated Horsepower
88 Liter Pump = 140 LB/HR X .9 = 126 LB/HR, Safe for 250 naturally aspirated Horsepower
110 Liter Pump = 175 LB/HR X .9 = 157 LB/HR, Safe for 315 naturally aspirated Horsepower
155 Liter Pump = 246 LB/HR X .9 = 221 LB/HR, Safe for 440 naturally aspirated Horsepower
190 Liter Pump = 302 LB/HR X .9 = 271 LB/HR, Safe for 540 naturally aspirated Horsepower
255 Liter Pump = 405 LB/HR X .9 = 364 LB/HR, Safe for 700 naturally aspirated Horsepower
Note: For forced induction engines, the above power levels will be reduced because as the pressure required by the pump increases, the flow decreases. In order to do proper fuel pump sizing, a fuel pump map is required, which shows flow rate versus delivery pressure.
That is, a 255 liter per hour pump at 40 PSI may only supply 200 liters per hour at 58 PSI (40 PSI plus 18 lbs of boost). Additionally, if you use a fuel line that is not large enough, this can result in decreased fuel volume due to the pressure drop across the fuel feed line: 255 LPH at the pump may only result in 225 LPH at the fuel rail.
My Comments:
A lot of people oversize the fuel pump by buying a 255LPH pump thinking that the fuel pump regulator will just pass the excess gas back to the tank. It does, but… Did you ever consider that circulating the fuel around as a 255 LPH pump does will cause the gas to pickup engine heat? What happens to hot gasoline? It boils off! With most of the 5.0 Mustangs having the carbon canister removed or disabled, the car stinks like gas, and the gas mileage drops since the hot fuel evaporates away into the air.
Thanks for the info i think the car has a stock fuel pump in it but im not sure.... so to be safe ill get a 155lph that should flow enough for what i need. appreciate all the help
BTW i have done research on my injectors and cant find anything about them not even who makes them but im sure they are chinese........ anyway to tell how much they flow?? My problem might be having the wrong injectors or six at 24# and two at another... maybe..
Its the BBK cold air messing with the C&L. Put a stock airbox and intake tube on with the C&L and see if it is better. IF you put a cone filter on a C&L it will lean it out about 1 full injector size, and if the CAI is on it with out a SAMPLE tube made for the CAI...it will not work.
Are you running stock heads? If so, 19 lb injectors should be fine. I have gt40x alum heads, b303 cam, 302 bottom end, running 24 lb. Get the 19 lb calibration tube from C&L, run the stock air box and it should be fine. I have a 76mm C&L with stock air box and K&N Filter, it works fine. That's true about using anything other than the stock air box with C&L on a Fox Mustang. I talked to the the owner of the company. He said that they couldn't get any gains from a conical filter and actually lost performance with a conical. The C&L meter is designed to be used with the stock air box. I put a conical on once at the track and went from 13 seconds to 14. I know other MAF set ups are better, but the sensors and tube are approx. $230.00. The C&L uses the stock Ford sensor. Just found one used for $25.00. My C&L came with the car so budget wise , that's what I use
I dont have the factory airbox anymore.... i called C&L and they told me that my CAI would not effect the output on the sensor. Im going to just cut the crap and get a ProM MAF.. Maybe some new injectors too.. the car is about to go under the knife, putting on a set of ported gt40's.. and 1.7rr. Im hoping to put alot of area under the curve, and have enough injector left for juice at the track.
The first thing I would do is get rid of the Chinese fuel injectors. Those injectors are Wofoto brand from China. Who knows what they're doing.
http://www.alibaba.com/product-gs/255761111/Injection_Nozzle_01D126B_Nozzle.html
A lot of people talk badly about the C&L meter housing. It's just a housing folks, you use the stock sensor in it. 99.9% of the time, if there is a problem with a C&L meter housing, there is something else wrong. There was just a guy over at the Corral that was having a problem with his C&L meter. Everybody told him to ditch the junky meter and get a real one. It turned out that the problem was with the junky hose he was using to connect the meter to the throttle body. It was pinching down when tightened, and closing the air off to the sample tube. He replaced the hose with a better one and now the car runs like it's supposed to.
