What The Maf??!
  • Thread starter Thread starter a91what
  • Start date Start date Jun 25, 2012
First Prev 2 of 2
Admin Dude
Jan 4, 1985
43,549
21,718
234
Box behind Walmart
Jul 1, 2012
#21
  • Jul 1, 2012
  • #21
Maryland Stang said:
The first thing I would do is get rid of the Chinese fuel injectors. Those injectors are Wofoto brand from China. Who knows what they're doing.
http://www.alibaba.com/product-gs/255761111/Injection_Nozzle_01D126B_Nozzle.html
A lot of people talk badly about the C&L meter housing. It's just a housing folks, you use the stock sensor in it. 99.9% of the time, if there is a problem with a C&L meter housing, there is something else wrong. There was just a guy over at the Corral that was having a problem with his C&L meter. Everybody told him to ditch the junky meter and get a real one. It turned out that the problem was with the junky hose he was using to connect the meter to the throttle body. It was pinching down when tightened, and closing the air off to the sample tube. He replaced the hose with a better one and now the car runs like it's supposed to.
If you understand that the housing and electronics are co-dependent on one another then you should understand why that makes no sense.
When Ford initially designed (or had designed) the meter it was with a SPECIFIC sensor installed in a SPECIFIC meter housing. There was an acceptable tolerance and error margin built into the final product. That margin of error was designed to be WITHIN the EEC's ability to compensate for with its adaptive strategy.
So.... Meter X and Sensor Y make up a MAF designed to SPECIFICALLY to function correctly with EEC A on engine B.
The sensor itself is fitted into a housing and measures say, 5% of the air that passes through the housing. It doesn't measure all of the air... just a small portion of it. A flow bench machine was used to ensure that, that 5% of the air is an ACCURATE sample of all the air that is passed though the entire housing under a LOT of different conditions. Small adjustments are made here and there to the housing itself to relieve errors caused by rough air flow, vortexes, etc. When it's finally right, it's packed up and delivered to the assembly line.
And then.... Billy-Bob while sitting in his mom's garage one day, gets this great idea. He can stuff those electronics into a larger housing to get even MORE air! Yeeeeeeeeeeeee-Haaaaaaaaaw. Only trouble is: Billy didn't realize that only 5% of the air mass was being measured. Low and behold, the car ran like crap. So what does he do, you ask? He creates a removable sample tube and reduces the amount of air being sampled from 5% to 1% to compensate for all the additional air passing through the housing. Billy has another great idea... he can toss larger injectors into the mix and use the sample tubes to fool the computer even more! GREAT! So Billy tries a bunch of different sample tube opening and learns that he can run 30 lb injectors and make the car run half decent if uses a really tiny opening in the sample tube.
Trouble is... Billy is now only sampling .2% of the air entering the meter housing and what's more... For some reason windy days make the car stutter. On calm days though, Billy's invention works pretty well except for low speed driving. Hmmmm. I guess .2% of 50 CFM at just off idle, isn't a lot to make a significant change in voltage on that sensor. Go figure.
Now... C&L APPEARS to be slowly getting better. They appear to be taking a little more time and putting in a little more effort. SOME of their newer housing are pretty nice from what I hear. Those are fixed housing with no removable sample tubes though.
If you think there's no errors to be made in manufacturing JUST THE HOUSING on a mass air meter, you'd be sadly mistaken.
Reactions: f8tlfiveo
Maryland Stang
1,656
30
39
Greenville, NC
Jul 1, 2012
#22
  • Jul 1, 2012
  • #22
I do agree that using a universal MAF is jut asking for trouble. But, I maintain that when used in an application where everything is functioning properly, the C&L is fine.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 1, 2012
#23
  • Jul 1, 2012
  • #23
Well i have to say everything is working just peachy. Swapped the meter out with a Pro m off a friends car and she ran Perfectly. No more issue's no rich smell at idle no stutter just ran like it should. So i have to say im sold on the idea that the C&L is crap.
Admin Dude
Jan 4, 1985
43,549
21,718
234
Box behind Walmart
Jul 1, 2012
#24
  • Jul 1, 2012
  • #24
Another dissatisfied customer.
Put it on ebay. There's still LOTS of folks that gotta figure it out the hard way.
Reactions: f8tlfiveo and 88LX5.Oh
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 1, 2012
#25
  • Jul 1, 2012
  • #25
What do you guys think of the KMJ 190cc aluminum cylinder heads? My dad wants to trade me a set for my ported gt40's he's wanting to run some class that only lets you use parts with stock casting numbers.
Admin Dude
Jan 4, 1985
43,549
21,718
234
Box behind Walmart
Jul 2, 2012
#26
  • Jul 2, 2012
  • #26
They're chinese knock-offs. Has your Dad been running them?
The reason that I ask is that quality control with these kinds of parts is hit or miss. If he's been running them and they've worked fine then press on with pride. I'd still have a machine shop look them over before installation to make sure they're flat. If they're in good shape, they (along with necessary supporting mods) will make more power than your GT40 heads.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 2, 2012
#27
  • Jul 2, 2012
  • #27
No he has not been running them he told me i could choose any set i wanted 190cc or 210cc...ect. For trade on mine. Im not sure if im getting a good deal or more headache.
Admin Dude
Jan 4, 1985
43,549
21,718
234
Box behind Walmart
Jul 3, 2012
#28
  • Jul 3, 2012
  • #28
Have a machinist check them over and make them right and you shouldn't have any problems. Have hardened valve seats installed if you ever plan to run boost or nitrous.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 3, 2012
#29
  • Jul 3, 2012
  • #29
sweet thanks you think i should get the 210cc heads? Or will they be to big to make the torque i need.
Rick 91GT
Mustang Master
95
99
PA
Jul 4, 2012
#30
  • Jul 4, 2012
  • #30
Those heads are lacking flow amongst other things...we swapped a 210cc set for a AFR 205 and picked up over 60rwhp. If you want a lower price alum head the RHS or 170cc TFS TWO are great.
Noobz, you should call and talk to Lee @ C&L one day. I called after being frustrated and was pleasantly surprised at the info and data we discussed.
fiveohwblow
Official Member
2,169
145
155
Jul 4, 2012
#31
  • Jul 4, 2012
  • #31
Pertaining to current pieces and tech involved, or future?
Admin Dude
Jan 4, 1985
43,549
21,718
234
Box behind Walmart
Jul 4, 2012
#32
  • Jul 4, 2012
  • #32
I'm sure he believes in his products and am equally sure that they have items in their line that are better than others. That doesn't mean that the ones that are inconsistent will suddenly become so. There are too many instances where the same products make repeatable and verifiable problems. Swappable sample tubes are one of those consistencies as are over sized housings fitted with electronic sensors that are expected to perform well in cfm ranges below those they were designed to operate.
Sent from my DROID BIONIC
fiveohwblow
Official Member
2,169
145
155
Jul 4, 2012
#33
  • Jul 4, 2012
  • #33
I wonder what six sigma is to c&l..... Meaning, my car runs, drives, and according to my three tuners I have spoken with is perfect. I wonder how there can be such a discrepancy amongst the users....
Wait, no I don't.....
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jul 4, 2012
#34
  • Jul 4, 2012
  • #34
All 6 sigma means is they manufacture their product 99.997% of the time correctly.. That does not mean that the design is good.
Rick 91GT
Mustang Master
95
99
PA
Jul 5, 2012
#35
  • Jul 5, 2012
  • #35
What I meant by my comment was since you understand how the meter works you could have a Technical, meaningful conversation with Lee and fill the blanks. There is a reason Im a ProM dealer.
First Prev 2 of 2
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
