- Apr 5, 2010
- 38
- 4
- 18
Hi all.
I have to fix a blown-out plug hole on my '96 Cobra. I'm in the midst of this epic disassembly and just removed the timing cover. To do that, I had to remove the water pump.
Of course, this unleashed a cascade of coolant and grime that went right into my oil pan (not to mention the timing chains). I conclude that I must remove the oil pan to clean it out, and this looks like the biggest pain in the ass of this entire job so far (and that's saying quite a bit).
I'm doing all this in a tandem parking space in a rental-apartment parking lot, so there'll be no engine hoist.
I suppose I could attempt to flush the pan from the slot that's available at the front of it right now with the timing cover off. I do have a borescope that I can use to inspect the interior. Not sure what the best flushing solvent would be.
But given the way that the timing cover mates with the front edge of the oil pan, how often do these things go back together without leaking anyway? I don't have reason the believe the gasket is damaged, but I haven't looked carefully.
Ugh, you get the picture. Recommendations welcome. I was feeling pretty good about the progress thus far, but the pain in the ass of removing this pan is very disheartening.
