What to do for Schrader Valve on 04
I've had several customer in the same boat and Fords replacement rails for 1999 up which came wth the schrader valve now do not. what my customers did was buy the fuel rail asbly for the 2001 Bullitt Mustang part # 2R3Z-9F792-BA and sells for @$150.00 comes wth the FPR and schrader valve.
Go to nitrousexpress.com and order their fuel block. It's $50.
On the driver side rail on the '04's, there's a fuel pressure sensor, that is held down by 2 bolts. You remove the bolts, remove the sensor, place the NX block in, place the sensor back on top of the block. The block has ports on both sides, one for fuel pressure gauge and one for nitrous. You just get a plug for the side you don't use. Saves you tons of money, and you leave the rails alone.
Thanks sgarlic...Thats the way to go Fuel & Gauge....Awesome......
