What to do with 1,000$
  • Thread starter Thread starter 84fiveohore
  • Start date Start date May 4, 2007
84fiveohore
23
york, pa
May 4, 2007
  • May 4, 2007
i have a stock 1990 302 a guy gave me... it has 39,000 miles on it.. i also have1,000$ what should i do.... ?i want to rebuild this motor and im looking for the best bang for my buck... now my father is a manager at an Advanced Auto Parts... so i get discount. but i was thinkin freshin up the bottom end and just buy rpm intake, rpm cam, rpm 2.02 1.60 valve heads.. and thats all... but i wanted ur opinion. so help a guy out...
thanks
dan
what i have
t-5
3.73 7.5
1 5/8 long tubes
thats about all
4G-KDMP
935
CA
May 4, 2007
  • May 4, 2007
only 39k ?
i wouldn't even think about rebuilding that motor!
K
krallman
96
Hurricane, WV
May 5, 2007
  • May 5, 2007
I highly doubt that motor would need rebuilt unless it had some very hard use or ran low on oil. I highly doubt your going to get all of that with a grand even with a good discount. I would either get a set of heads or go with a intake/cam/exhaust to get you going. 2.02/1.60 is probably going to be a little much much flow for what you would have. Are you goign to run carb or f.i.? If you are goign to run carb. on that motor i would switch out your distributor from your 84 and use a steel gear. I would also swap out your timing chain cover so that you can use your mechanical fuel pump.
D
Daggar
3,902
  • May 5, 2007
--moved to Talk--
KurtPB
127
Lorimor, IA
May 5, 2007
  • May 5, 2007
umm, possi & tires?
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • May 5, 2007
2 chicks at the same time
cenok is family
1,409
69
79
Norman, Ok
May 5, 2007
  • May 5, 2007
thanks
dan
what i have
t-5
3.73 7.5
1 5/8 long tubes
thats about all
get an 8.8 if you're planning on putting on a h/c/i combo.
gcwh02
515
pottstown, PA
May 5, 2007
  • May 5, 2007
i was going to say a few champagne rooms
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
87 GT with cam and headers. Do I need an aftermarket manifold and TB
  • Scarlet Fox
  • Nov 12, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2024
65ShelbyClone
Motor given to me and I’d like to rebuild it what do I need to do
  • Creomod
  • Dec 14, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 16, 2024
AeroCoupe
